Question about Brother DCP-8060 All-In-One Laser Printer
Paper jam is in top but can not see it.the paper feeds thru the tray then pushes itself out the top.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 30, 2009
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Paper jam up in top of printer Tray one wadded badly -
Try using the cardboard backing of a large writing tablet by sticking it down into the tray where the paper goes. If there is a small piece of paper there, it will be pushed out.
Marie
Jan 26, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Brother DCP-8060 All-In-One Laser Printer Logo
207 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
