Question about Asko W6021 Front Load Washer
Randomly incomplete washing cycles
My washer, with no particular rhyme or reason, will sometimes end washing with the dial pointing to "C" which supposedly indicates "...a problem which can be taking care of without calling a service technician." This happens maybe 10-15% of the time, and there is no consistent set of circumstances which I can discern. I clean the trap at bottom left fairly regularly, and that does not seem to influence the outcome. I can't say at which point (e.g., rinse, spin) the washing ends and spins to "C". It does seem that the clothes may have gone through an incomplete spin, as they sometimes feel heavy, but I'm not sure if they've had a complete rinse cycle. They don't smell or seem particularly soapy, but I use the HE soap, and I use it sparingly. To get the clothes out, the machine must be tricked: I turn the power off, turn the dial to the "done normally" position, and turn it back on. Only then can I push the door release button. ASKO is a real headache--they were installed in a condo I bought. (Of course, the 5-year warrany expired 1 month before the real problems began.) I've already rebuilt parts of the companion dryer.
    Novelist:
  • 114 Answers
SOUNDS LIKE YOUR DIAL/TIMER POSSIBLY HAS A STRIPED COG ON EITHER THE DRIVE OR WHEEL GEAR
Posted on Apr 28, 2007
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
My washing machine washes and then stops at the rinse cycle...but you can hear tick, tick, tick...and then the dial moves but the clothes don't get washed! Same for the spin cycle. If I push in the dial...
if it keeps sticking in the same place and then if you advance the timer past that point and it runs again the points are burnt out in the timer and it needs to be peplaced.a new timer is around 90 dollars and the part number is 8546165.when you call your parts store give them the full model number off of the machine to make sure it's the correct part number,you're missing a number and letter at the end,the number i looked up was LSQ9549Lg3
Apr 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water left in machine (clothes dripping) after delicate cycle
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Washing machine not spinning at the end of cycle
if the dial is moving round as normal and the machine is filling and emptyin change the motor brushes this will cure the problem
Dec 20, 2008 | Hotpoint First Edition FEW12 Front Load...
Whirlpool washer stops in mid cycle
check the connection at the main control board top right side just remove the top
Nov 29, 2008 | Washing Machines
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Asko W6021 Front Load Washer Logo
169 people viewed this question
Top Asko Washing Machines Experts
Marvin
Marvin
Sal De
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
