Question about Taylor Dgtl Body Fat Scale
Error message every time i get on my scale it reads error 2, what does this mean and how can i fix it?
  • dengerer Jan 04, 2009
    I'm having the same Err2 issue with my Taylor scale. I have talked to others with the problem, but no one has yet told me of a solution.
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Posted on Feb 17, 2009
After trying several other things, what finally resolved this issue for me was removing the battery and leaving it out for 24 hours. I then put the same battery back in and it is working fine again. Hope this works for you as well.
Posted on Jan 05, 2009
I don't have a Taylor, but that E often appears on mine when I first step on it...the instructions indicated the scale is calibrating...step off and tap the scale twice and wait for 00 to appear..worked for me every time..hope that helps..be well..Jack
Posted on Dec 29, 2008
What does oue2 mean on the scale
Best Answer: Most digital scales have this message (OUTZ) and it can mean that your scale has been overloaded or has simply lost its calibration. If the scale was overloaded, then it is probably done for. Sometimes you can try recalibrating the scale using the manual to fix it. If the scale was delivered with this message, then I would call the manufacturer to have it replaced because it is considered DOA. If it has been some time since you purchased the scale though, and it was damaged from overloading, you may be out of luck, as overloading wouldn't be covered by warranty.
Scroll down a few sections on this page to section 4.
http://www.awscales.com/support/faqs
Oct 10, 2016 | Health & Beauty
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Long sleeve shirt why did you weigh scale reads 0 - LD what's that mean
    Are you sure it wasn't 'lb', which is Latin for pounds?
    Mar 26, 2016 | Health & Beauty
    What is error code 2402
    Error code 2402 is displayed, means unit is wet, time to purchase new scale. Cannot be fixed sorry.
    May 25, 2014 | Terraillon 5 Kg Maya Scale
    Sw13 scale reads HHH
    Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
    May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
    My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
    my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
    Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
    I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
    From the Taylor Site http://www.taylorusa.com/faq-scales
    Here are the basic ERR messages and their meanings:
    • Error 0: Initialization
    • Error 1: Instability (scale is on an uneven surface ex: carpet)
    • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
    • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
    • Error 4: Body fat is out of range
    • Error 5: Water is out of range
    I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
    1. Remove the battery from the scale.
    2. Sit the scale on a hard surface floor.
    3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
    4. Re-install your battery.
    5. Place the scale back on a hard surface floor.
    6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
    7. Wait for the scale to turn off again.
    8. Step up onto the scale for a weight.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jan 15, 2010 | Health & Beauty
    Err 1 message on Taylor Lithium Elec Scale model 7346
    This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
    Thank you for your e-mail. The reboot below may clear the error from
    your scale. You may need to do this several times to completely reboot
    the system. Please let us know if you have any questions or continue to
    display the Error.
    2. Set the scale on the floor without the battery in place.
    3. Stand on the scale for 10 seconds (still without the battery)
    4. Carefully replace the battery without turning the scale on.
    5. Using only one foot, tap the scale or apply just enough pressure to
    turn on the display. (It should show dashes or zero's) IMMEDIATELY
    REMOVE YOUR FOOT.
    6. Let the scale turn off
    7. Step on the scale for a weight reading
    Regards,
    Linda DLT
    Consumer Relations
    Taylor Precision Products
    & Salter Housewares
    2220 Entrada del Sol, Suite A
    Las Cruces, NM 88001
    Toll free - 800-289-0944
    866-843-3905
    Direct - 575-526-0944 ext 3172
    Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
    Error 5 for ncr 7875 scale scanner
    If the scanner read only two times is a problem with the communication protocol.
    What protocol do you use?
    Explain more about your problem with your calibration pricedure
    Jul 29, 2008 | NCR 7875
    Taylor Dgtl Body Fat Scale Logo
    2,151 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
