Question about Nokia 9500 Communicator
Nokia 9500 doesnot boot
One day my 9500 fall from my pocket after about 6 hours when the battery was nearly charged out it switched off. when i tried to reboot it after charging the battey fully it didnot boot after the initial nokia screen. after the nokia screen the hands didnot appear only lit up blank screen appears morever the outer screen doesnot switch on at all.plz help
  • sanjay verma Apr 29, 2007
    the link is not opening. morever, in the faq there is no solution for the problem.
  • andyblue001 Mar 25, 2008
    Still I also experience startup problem, and I did not even dropped of my 9500, it just blink when I tried to turn on. What should I do? Is that a hardware problem? cuz I already tried formatting it but still I get the same effect specially when it hangs or turned off..thanks
  • 43 Answers
Hi for this problem == plz check this out www.nokiausa.com/support/phones hope you can get your cell back as it was! GOOD LUCK
Posted on Apr 28, 2007
SOURCE:
Had phone almost a year, no problems. Couldn't get it to turn off, so removed battery, now won't go on, tried all advise, cept battery out for 6 hours, will leave it out, but have you heard of this? Can...
It could be that moisture got into the battery terminals. Take a Qtip and wipe the battery terminals inside the phone and also on your battery.
Then try installing the battery again and then hook up the AC charger. Try booting up. I had a cell phone once, it was a Nokia and it did something similar. I had plugged the car charger in while I was in the car and I heard a noise like it shorted. I took the phone to trade it in when I purchased a new Nokia and I noticed that the store clerk had taken my phone that would not boot up and hooked it to an AC charger. It powered up. I still purchased the new phone, but try the AC charger and see what happens. If it powers up, it might be the battery. Let the battery charge for about 4 hours, don't keep it charged overnight. Overnight charging will ruin the battery. If the phone still doesn't work, I'd say bring it in and see if you can get it looked at.
Mar 27, 2010 | Nokia 5800 XpressMusic Smartphone
My Nokia E63 doesnot switch on
Remove your battery from phone and insert it again then charge your phone for 5 to 10 minutes.After it, if its display does not come then replace the battery.
Try it, if not switch on, inform me at pariharpradeep@rocketmail.com
Feb 01, 2010 | Nokia Lands Phones
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Oct 18, 2008 | Nokia N800 Tablet PC
Nokia 9500 brand new won't even boot up, how do i fix this problem
You just mentioned that Nokia 9500 is brand new... so why not contact Nokia care and ask for warranty support ??
E-mail Nokia at : https://www.nokiausa.com/A4450098
(For Nokia USA)
Here is the Nokia site locater :
http://www.nokia.com/locations
Goodluck :-)
Jun 05, 2008 | Nokia 9500 Communicator
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Nokia 9500 Communicator Logo
285 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
