Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV56-WP74 Convergence problem
About 6 months ago I had a convergence problem and the tech replaced the two STK392-110 ICs and I had a beutiful HD image until last night when I accesed the convergence setting and did a auto adjustment. I trew off the red color and even after I did a reset and several manual adjustments I cannat make the red align on the outer areas of the grid specially the top and left bottom corner.
I wander if I need to replace those ics again.
    Genius:
  • 1,139 Answers
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 29, 2008
Jvc 52 rear orijection top has doulbe image in
Ur convergence is dead.Must know how to solders?Must replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 14, 2010 | JVC HD-52Z575 52" Rear Projection...
Toshiba 55H70
It could be that this time the convergence module went. I have replaced many convergence ICs and don't believe I have ever had any go out within 6 months. That does not mean that they can't. Remove the leads from the convergence area to isolate the ICs as you said you were told. Now remove the digital convergence board which should be nearby and probably will be in a metal box for noise protection. If you can I would unsolder the convergence ICs to totally take them out of the circuit and just in case one or both shorted out. Once everything I talked about has be removed try the unit. If your problem is in the convergence only your set should work but have an ugly picture. Let me know what you find and we will go from there.
hardrocko
Feb 06, 2010 | Toshiba 55HX70 55" Rear Projection...
HAVE A JVC AV-56WP30 REAR PROJECTION TV THAT THE PICTURE APPEARS IN A BOWED SHAPE. THIS TV WAS JUST REPAIRED FOR THIS PROBLEM ONE WEEK AGO AND IN 100 MILE DRIVE TO PUT IN APARTMENT IT IS AGAIN NOT WORKING....
The convergence is dead,Must replaced Convergence ICs and resistors.Tell the shop to repair it again.They probally didn't replaced the ICs or resistors.This problems can't come back about a week,at 6 months i can understand.
Jan 11, 2010 | Televison & Video
I have a jvc/av-65wp74 unit. The screen went blank and made a pop,pop,popping sound. we could not shut it off with the power button, which was blinking off and on. We had to unplug from the wall. we waited...
Try unplugging the Convergence amp board, which is located behind the speaker grille. If the set will power up with the Convergence amps unplugged the ICs will need replacement. I have seen many JVC in both the WP30 and WP74 pop through the speakers when the ICs short. Unplugging them takes them out of the equation and the set will power up but the pic will have severe convergence issues.
Dec 03, 2009 | FixYa Service
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
Conversion probleme with jvc av-48wp74 i did the set-up but dont want to keep it
you need new convergence ICs STK392-110 ICs and the JVC convergence resistor Kit #1 you can get the parts at the following link with free instructions and free online tech support to help you with the final adjustments after install. Here is the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Televison & Video
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
173 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
