Question about Zanussi WJS1265W Front Load Washer/Dryer
Drum is not moving
I have a Zanussi 1250 washing machine. When the door is shut, everything seems to be working except but the drum is not spinning. Washing stinks, I have played around with the programs but it doesn't seem to be the problem. what can I do to resolve this problem.
  • sexychick Nov 17, 2007
    washing machine drum not spinning but when it is on a spinning programme the water is drained out
  • Anonymous Mar 17, 2014
    Indeset 1100 WB111
It sounds like the drum drive is broken ... could be a belt at the back of the machine or it could be gear driven ... most likley a belt... take off cover on back of machine to see if the belt is broken and replace if necessary. Also could be pump but that is probably the last thing to go wrong pumps rarely ever fail.
Posted on Apr 28, 2007
    President:
  • 1,294 Answers
Try 'spin' only, to siphon out the water.
2 Suggested Answers
SOURCE:
  • 1462 Answers
SOURCE: Drum is not moving
as a first step, check the motor brushes for continuity across the commutator. take brushes out and release them from the motor to see if worn. this can be done with motor in situ but you may find it easier to take the motor out completely
Why is the drum on my machine isn't moving?
check ur drum belt or the wheel pulleys and in some cases the center bearing and shaft? my suspicions lie with the pulleys fairly inexpensive and not to hard to replace
Jul 25, 2014 | Zanussi ZWF1230W Front Load Washer
My zanussi aquacycle 1000. Programme knob is just cycling through the was cycle really quckly without the machine washing, the drum is moving slightly back and forth and sounds like its trying to engage...
Could be that the drive pulley behind the drum has loosened on the shaft. You do not say that you can hear the motor, but the drum moves slightly. Some machines have a shear pin which fails to prevent damage to the drum and motor. If you machine has one of these, it will be obvious when you get the back off. The lack of load on the motor could do strange things to the programmer. Good luck.
Jan 31, 2018 | Zanussi F1045W Front Load Washer
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
My zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Oct 12, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Drum is not moving
Apr 28, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
636 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
