Question about Sony Handycam CCD-TRV11 8mm Analog Camcorder
Samsung vp-d361 tape won't load. 'eject...d' displays
I haven't used my samsung vp-d361 for a year or so and it displays '(eject symbol)...d'.
it won't load the tape. with a lot of persistance it might eventually load only to be told to eject the tape again. the battery is fully charged. i cant see a reset button anywhere.
i've done the suggested routine in the manual with no effect. is this
something i can sort myself?
it was working perfectly before i put it away for the year or so.
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
Posted on Sep 15, 2006
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
SOURCE: re-attach the power source flashing
I had the same problem. I took off the battery pack and wiped the it down with a kleenex as well as the socket in the camera where the battery pack connects to. This fixed the problem.
Posted on Mar 15, 2008
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Posted on Jun 16, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony DCR-HC40E Tape Holder Mechanism load failure
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Posted on Jul 27, 2008
When I open the tape eject it pings but does not push out the tape holder, any fixes?
hi,
please check the mechanism side, if you left your cam for a long period with cassette loaded position, the tape will stick on the head and roller of you cam, if so you have to manually loosen the cassette reel from.
Mar 30, 2016 | Samsung VP-D361 Mini DV Digital Camcorder
Samsung VP-D361 Mini DV Digital Camcorder - have not used for a year and now it will not close the tape compartment. I have tried several tapes but when you push the tape in and push down the edge to close...
will it close with out a tape in. if its not doing it with the tape in there is a motor that pulls down something cannot remember its name. so when the deck goes in it can lock in place and hit the switch. if the switch has been damaged it will just eject the deck again. has one swith to say tape in and other switch is for table loaded. sounds like the loaded one is at fault. happens if you leave a tape in for a long time and not been used.
Sep 30, 2013 | Samsung VP-D361 Mini DV Digital Camcorder
Getting eject d message when i put a tape in my samsung mini dv, d361
make sure the camcorder is in "off" mode. then insert the tape. should solve the prob.
Feb 28, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
Display has eject "d"
this is a tape transport problem. something is broke inside..samsung builds their transports outta plastic. they get broken easily
Jul 13, 2009 | Sony Handycam CCD-TRV11 8mm Analog...
Samsung camcorder vp-d381 eject L fault
YOU CANT CLEAR IT. THIS SOUNDS LIKE THE TAPE TRANSPORT IS BAD. SOMETHING BROKE INSIDE TRANSPORT AND NOW IT WONT ALLOW YOU TO LOAD TAPES
Feb 21, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Camera won't record a D comes on screen and eject tape comes up.
I have a cam corder model VP-D361 PAL, since i brought i could not use it even a single time, for the past 2 yrs it was kept as it was brought in packed condition, i was using other cam corder of jvc, when i opened and start using it, i found a triangle and a D on the screen, several attepts made by taking out battery, and casset. but still same thing appears,(AFTER REFERING TO USERS MANUAL) it may be a simple problem, or a defective one, since brought a single minute is also not used, kindly help me to solve this problem from a local serviceing centre.at mumbai, india.
My address as below,
K.J.SEBASTIAN
BLDG NO. 7, FLAT NO. 29
BORLA CO OP HSG SOC
DR.C.G.ROAD
CHEMBUR, MUMBAI- 400074
TEL NO. 91-22-2520 5842
MNO: 9892004970,9987904458
Jan 18, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
I have a samsung camcorder and it keeps giving me a eject "d" error and i need to use it tomorrow. Can anyone help me?
YOUR TAPE TRANSPORT IS BAD. THIS EJECT D IS A CODE FROM SAMSUNG WHEN YOUR HEAD OF THE CAMCORDER IS BROKEN
Dec 10, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Samsung vp-d361
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Apr 18, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
EZECTING TAPE LOADER
  1. Eject the tape.
  2. Set to OFF.
Manual
Mar 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Sony Handycam CCD-TRV11 8mm Analog Camcorder Logo
78 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
