Question about Sharp FO-DC535 Fax
Sharp FO DC535 fax will not come to ready
Screen flashing please wait
  • 48 Answers
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
Posted on May 25, 2009
Our office uses a Sharp FO-4470 fax machine. this morning it is flashing an error on the display of High Voltage Error. Can anyone help with this?
It probably means that the high voltage driver board is blown. You'll have to take it to a service center for repair.
Feb 18, 2011 | Sharp FO-4400 Fax
Tip
How to get the page count for a Sharp FO-5700 fax machine
Sharp makes a line of fax machines, one of which is the FO-5700. The FO-5700 is easy to maintain and to use, and it can run well for years. If you want to view the life counter (page count) for your FO-5700, just follow the steps below.
With the fax machine on and ready, flip up the bar that displays the information for half of the quick dial buttons (#17-32). This bar has a tab that you can use to flip it, which sits right by the panel release lever (where you would put your hand to raise the operation panel if you had to remove a paper jam there). Just flip this bar up so that it covers the first half of the numbers instead of the second.
Once the bar is flipped up, you'll see that the V button is labeled "Life." Press that button to bring up the counter menu. Then press 1 on the fax machine's number pad. The screen will display "1: Life Counter" and below that, "LIFE=xxxxxx" where "xxxxxx" is the page count of the machine, in six-digit format.
You can view this life counter at any time, without having to print out a configuration page or usage page. To exit out of the life counter screen and return to the main screen, press the red Stop button. Be sure to flip the contacts bar back to its original position; there is a sensor that detects which way the bar is laying, and if it's still in the up position, pressing a button will have a different effect than it would if the bar were in its original position (such as bringing up the life counter instead of dialing a number).
on Jun 12, 2011 | Sharp FO 5700 Plain Paper Laser Fax
How do I reset counter?
only service engineer can do that at a price
Nov 04, 2010 | Sharp FO-DC535 Fax
LIGHT IS STILL ON WHEN i CHANGED THE DRUM ON THE FAX MACHINE
C -Photo-C-Photo insert 24 start press 7 start
Dec 08, 2009 | Sharp FO-DC535 Fax
clear the drum counter. life than down arow until it says drum counter clear than start 2 times
Mar 23, 2009 | Sharp FO-DC535 Fax
Sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
International faxing
Dial it as you would dial from a regular phone.
Ask the operator for the Country Code.
Sep 02, 2008 | Sharp FO-DC535 Fax
Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
Apr 23, 2008 | Sharp FO 5550 Plain Paper Laser Fax
How many fax numbers can be stored on the FO-DC535?
You will need a larger unit with more memory 32mb.
Oct 22, 2007 | Sharp FO-DC535 Fax
Sharp FO-DC535 Fax Logo
157 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
