Question about Rockwood AMP-225 Car Audio Amplifier
Power connection I cannot find the power cord that is connected to the amplifier .Need to khow how to distinquest the 12 volts, nuetral,and rem on the amplifier
  • eyemfedup2 Apr 08, 2009
    3 pin power connector wich is pos neg and whatever the 3rd one is
    thanks
  • Bo Trevathan
    Bo Trevathan May 11, 2010
    Do you know the type of amp? I have never heard of any other than a factory amp not having markings at the connection post.
Where connect rem connection
rem goes to the back of the headunit to a cable (blue or blue/white) that should say, either rem out or power continuous (PO CON) and needs to connect to the amplifier where it sais rem power(12v)
hope this helps
...andy...
Jan 05, 2014 | Car Audio & Video
What does the wire that comes out of the back of the amplifier that says REM hook to?
It connects to a fused, switched 12 volt power source; one that comes on when the radio comes on, preferrably the blue/white wire from the back of an aftermarket stereo.
Sep 16, 2010 | Lightning Audio B2.300.2 Car Audio...
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
Where is the power switch, or how do you get the power running through to get blue light to turn on?
There is a terminal marked REM it's between the + 12 volt and Ground terminal.
The REM terminal needs a power source connected to it to turn the amp on and off. It's usually the blue remote wire coming off the head unit.
This turns the amp on when your head unit is on and turns the amp off when the head units off.
May 21, 2010 | Pioneer GM-3100T 300W 2-Channel Amplifier...
I have two amps one for my speakers and the other for my subs it was working fine but recently one of them turned off. I thought was a short circuit and bought a new one but still doesn't work. Its looped...
When running multiple amps you need a relay most of the time for the remote wire off the radio this is because the radio was built to power one not multiples. one 12 volt relay may help .check local car audio store. also when hooking up relay it has to have a 12 volt power wire connected to it usually the center pin on the relay is your connection for the power wire the you connect your remote wire from the radio to the relay then connect each amp independently to the relay. Hope this helps write back if not . and if so leave feedback
May 09, 2010 | Stingpro ST444 1850 Watts Complete...
Where does the rem wire plug into
It plugs into the power antenna cord on your radio if your radio does not have a dedicated remote cord. The remote switch is so that you amp can detect when your radio is on and turn on too, or is off when your radio is off so as not to drain the battery
Sep 23, 2009 | Eclipse (XA1000) Car Audio Amplifier
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
I have my amp hooked up but it isnt getting any power can you tell me if i have a bad amp or if i need the speakers and sound for it to come on?
With all amplifiers for a car, you must have the main power connections B+ and ground connected, and then you must also have the remote turn on connected as well. This is the way the amp turns on. It comes from the radio and is usually the blue wire from the harness off the back of the radio. When the radio is turned on, the blue wire gets 12 volts sent to it so it can turn on an external device like an amplifier or the power antenna. Make sure you have this connected to the amp and that the radio is turned on. Then check the voltages at the power terminal of the amplifer. You will have the ground, the main B+ of 12 volts, and then the turn on voltage of 12 volts. If you have all of these, then you need to troubleshoot it more. It will turn on without the speakers connected, but I am not sure why you would want to connect it without the speakers. It will also turn on without the RCA cables connected for the audio input as well. But just to turn on the amplifier, all you need is those three things i mentioned. Let me know if you require any further help.
Jan 23, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Blue amp light lights for 2sec
There may be more than one problem. The fact that the radio AND the amp are seeing a voltage of 7v indicates that the battery is weak or there is a bad connection somewhere in the power line.
It's also possible that the amp is defective (shorted output transistors?) and when it turns on, it's drawing excessive current. That would cause the voltage to drop more than normal. If the amp is drawing excessive current AND there is a bad connection in the power line, the amp may begin to blow fuses (depending on the reaction time of the protection circuit) when you repair the power line problem.
Apr 25, 2008 | Sony XM-1252GTR Car Audio Amplifier
Rockwood AMP-225 Car Audio Amplifier Logo
79 people viewed this question
Top Rockwood Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Lawrence Oravetz
Are you a Rockwood Car Audio and Video Expert? Answer questions, earn points and help others
