Need to know what hardware and connecters needed for install
SOURCE: LMS 332c Power cycles on own
i've repaird this by installing a secondary powerswitch and disconnecting the power switch on the keypad. It's an involved repair but it can be done.
SOURCE: Need install instructions lowrance Pc-26BL power
This power cable splits into three ends: a power supply cable, a NMEA 2000 power cable, and a NMEA 0183 data cable. Check this reference diagram (click image for zoom)...
Hope helps.
SOURCE: My Lowrance LMS-332C GPS was
Hello 2# Make sure the power cable is wired properly. The red wire connects 4# Measure the battery voltage at the unit's power connector. It should be at least 10 volts. If it isn't, the wiring to the unit is defective, the battery terminals or wiring on the terminals are corroded, or the battery
If the GPS works and sonar section does not work at all, check the followings.
1# Check the power cable's connection at the unit. Also check the wiring
to the positive battery terminal, black to negative or ground
3# Check the fuse.
needs charging.
Check whether there have any wiring break, loose. During servicing the boat, there is chance to get the wiring of sonar to sonar sensor at the botom of the boat may have damaged. Check these. OK.
SOURCE: lms-332c lowrance fishfinder unit turns
well, you should beging by doing a soft reset..hold the pages button down as you power up to do the soft reset. if problem persists, then you are most probably having a keypad problem.. some button is stuck and anything could cause that.. even moisture. i recommend you have it serviced by tech in this case.
Regards
SOURCE: lms-332c lowrance fishfinder unit turns on as soon
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
