Question about Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP16 No Power
Hi, I was wondering if the scaler board fixed the problem with your 50hp16, mine has the same problem. I checked the volts like the troubleshooing says and get the same results.If not what was your ifx. Thanks, Nick
    Problem Solver:
  • 5 Answers
I bought a Scaler board from someone on eBay but it did not fix the unit however I'm not sure the replacement was not a dud. I planned to send the board to PTS Corp but haven't yet. I have sent other boards to PTS wit good success. http://www.ptscorp.com/tech_support.html
Posted on Dec 30, 2008
My Toshiba 50hp16 stuck on standby mode
Could be an open internal fuse or power supply failure
Dec 07, 2016 | Toshiba Televison & Video
Picture but no sound on a Toshiba Theaterwide HD tv
Hello Iam wondering have you tried to see under the TV setting Audio and see if the fuctions are muted
or try to unplugged the tv and wait for a few minutes plug it back in.
Also when th tv is turn back on or unplugged and plugged back in see if the power button light
flashes red
And listen to the speakers to see if there is a faint crackling
Sep 12, 2008 | Toshiba TheaterWide 50HP16 50 in. Plasma...
I have a 6 yr old toshiba 50hp16 that is currently not working. I was watching the tv last night...heard a pop...and noticed the picture got darker and the pixilation got very grainy. The television...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 11, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
I have a Toshiba #50HP16. The picture just went out without any warning, could still hear the sound. Turned it off and now it will not come back on, not even the sound. You can hear licking like it is...
U hear alots of clickings,when power turn on?Yes,the tv projection lamp might be dead also,require replacing?But the board call the Ballast board is 100% dead.This Ballast board job,it to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy parts like projection lamps and Ballast boards for DLP projection tvs brands.
Oct 19, 2010 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
TV repair person told me my Toshiba 50HP16 Main Power Supply Circuit Board is bad as well as a secondart board. How do I identify these boards and get part numbers? Its too expensive to have the repair...
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Sep 19, 2008 | Televison & Video
Toshiba 50HP66 50 in. Plasma Television Logo
452 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
