Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer is taking 3 cycles to dry????
It seems that I am running my dryer for about 3 cycles to dry one load of clothes! Any ideas???
  • amy4718 Dec 31, 2008
    I have checked both of those options??!! Any other thoughts?
Have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Posted on Dec 29, 2008
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Our Whirlpool Duet electric dryer will is not
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
My whirpool dryer (Duet) seems to always take (2) cycles to dry...After the first cycle the clothes are still very damp.
Your dryer may be pushed too far back , causing the vent hose to kink , behind the dryer . Also , check the outside vent airflow , and check the lint screen holder , for any peeled off lint , which could also be blocking the outside air flow .
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes not drying
is this a washer or dryer if its a dryer you need to check the air flow where the dryer vents outside the house make sure it is flowing good it may need to be cleaned out
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Do you have an idea why our 3 year old whirlpool duet gas (propane) dryer takes several cycles to dry clothes, sheets & towels? this does not seem energy efficient and why we purchased the dryer in...
the most common problem 90% of service call blocked vent dirty or crushed behind in wall also may have blockage if not a thermo stat is bad
Apr 19, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal De
