Question about Microsoft Xbox Console
DAWN. XBOX 360. i have three red lights around the on/off switch
Can this problem be solved?
  • 70 Answers
Yes I had the same problem dont send to Microsoft it will cost 140 dollars plus shipping and you have to wait 2 to 3 months to get it back. Go to http://xbox360repaircenter.info and you will be playing in 2 hours guaratnteed for cheap. When I did it it was less than 2 hours Highly recommended
Posted on Jan 09, 2009
Blinken red light around the power button
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Jul 26, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
THE XBOX HAR RED RINGS AND WON'T COME ON NOW WHAT DO YOU DO?
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console or power supply., to try and quick fix - rap a couple of towels around the console and switch the console on leave for five mins. then switch off and on again the problem should be fixed- however this is not a long term solution
Mar 21, 2010 | Microsoft Xbox 360 Console
How do u fix the three red flashin lights on the 360
(do it on your own risk} it has 70%chances to problem solved.
it is just a trick dont blame me if anything happend
try to unplug all wires and replug ***
1. run xbox for 1/2 hr
2. wrap (cover) ur xbox in towels , wait until it get switch off by itself(due to over heat)
3. unplug the xbox , shake it in all direction for 10-15 sec , hit slowly on both sides of xbox
4. now switch it on , if u find any red ring then, cool the xbox using (a/c, fridge ) not for too long.
i think the pro will solved
Mar 05, 2010 | Microsoft Xbox 360 Console
Flashing red light
if its three of one red light, its broken and youll need to send it to microsoft for repair
Dec 30, 2009 | Microsoft Xbox 360 Console
Red light flashes sometimes and not reading disks
Hi carla 0166,
Its not good news im afraid, that red light that flashes on the console is also known as the "ring of death".if one segment is red its not too bad but if its any more it wont work.
To get around this as daft as it sounds you need to overheat the xbox 360.
i know this as it has happened to me also.
simply switch the x box 360 on and then wrap a towel around it and leave for 30mins.
this will overheat the console and when switched back the red light should be gone.
I hope this has helped :)
Sep 18, 2009 | Sega The Club - Xbox360 for XBox 360
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
X-box 360 wont turn on
If the lights are red, this means that your 360 has had a hardware failure. This failure is also known as the "Red Ring of Death." If you have bought your XBOX 360 with in 3 years of posting this, your will still have free 3 years of warranty from Microsoft. Call them at 1-800-4my-xbox. (1-800-469-9269)
Hope this helps :)
Jan 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
