Question about Microsoft Xbox 360 Console
Can't connect to wireless xbox360 live
When setting up, I get to "enter DNS server" & my entry 192.168.1.1 is always rejected. It asks for a secondary server also, I ignore this. Should I enter the same DNS details for this server also?
My ISP is TalkTalk.
  • 3 Answers
You need to contact your ISP. I have never heard of TalkTalk, but if its a DNS problem, its your ISP.
Posted on Dec 29, 2008
My laptop wont connect to my wireless router, it just says acquiring network address all the time, it does connect to other wireless routers though?
To connect a laptop to a wireless network for accessing internet....you have two ways:-
1. DHCP (Dynamic Host Control Protocol) 2. Manual entry of settings in wireless adapter properties.
1.DHCP:- In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network router settings.
2. Manual entry of settings in wireless adapter properties. This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
* IP address (Its format is "xxx.xxx.xxx.xxx") * Default gateway address (very important) * Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast) * Subnet Mask (not needed mostly...automatically generated)
To enter these settings you have to rightclick the Wireless Adapter>> and select properties>>Then double click the Internet Protocol version 4(TCP/IPv4) and enter these settings. In many cases when you are using proxy server then you have yo use proxy settings also in your browser..
Hope this will help 4 sure....Cheers..:)
Sep 30, 2010 | Acer Aspire 3610 Notebook
Hi i try to connect to my wireless but none of the network places come up it say's 'turn on wireless capability' theres two button underneath the laptop i tried but it doesent work PLZZ HELP!!
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
Hope this will help..........Cheers:)
Sep 25, 2010 | Acer Computers & Internet
Need to set up wireless router
you have two ways:-
1.DHCP:-
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
Need help connecting wireless router
1.DHCP:-
Hope this will help....Cheers..:)
Sep 25, 2010 | Computers & Internet
Plz tell me if a laptop can connect to the internet using it's wireless connection if settings for the internet are used.and if it is poossible to use it,pliz tell me how! i'll be very greatfull. thanks
1.DHCP:-
Sep 24, 2010 | Computers & Internet
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Netgear wireless n modem router type DGNB2100-100UKS problem dropping out on games when playing on xbox live
You can consider following steps to for the x-box live with netgear dgnb2100:-
a)Get any computer which has the internet access to it , Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go.
b)Enter the username and password for the router (Default username is admin and password is password).
c)You will be navigated to router administrator page , you will have a blue/purple column on the left hand side which has the different setting options in there.
c)From the browser Main Menu select Advanced and then the sub-title WAN Setup.
d)Under WAN set up,check the box for Default DMZ Server enter the server's IP address[192.168.0.20] the corresponding box for the IP Address.
e)Click Apply.
ON X-box live:-
a)Open the main menu and under setting's select wireless set up and then select manual setting's , it will ask to enter the following information:-
ssid(broadcast name)
security type(wep/wpa-psk) and password to it
ip address:-192.168.0.20
subnet mask:-255.255.255.0
default gateway:-192.168.0.1
Primary DNS:-192.168.0.1
Secondary DNS:-leave that blank and apply the setting's
b)Go for the connection test and it will have the successful connection.
This Link will be of great help:-
http://kb.netgear.com/app/answers/detail/a_id/1118
Nov 28, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Roy lee
Finally the DNS problems I had with connecting my PS3 to my network has been resolved. I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Aug 26, 2008 | Sony Playstation 3 (PS3) Console
Hooking up my playstation 3 to the internet with a wireless connection
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
