Question about Linksys Wireless-G WRT54G Router
Our neighborhood is using our internet!
I would like our router to be only used by those that I have given the password to. How do I make it secure?
  • 340 Answers
Connect a computer to any one of the four LAN ports of the router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.0.1 or 192.168.1.1 or 192.168.2.1) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings. Please write down the key – You will need it later to configure your neighbors wireless computer with the same key.
DO NOT GIVE HIM the password for the router.
Remember to set the admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Posted on Dec 29, 2008
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
Dear Sir, I bought a Linksys E1000 Router for my Internet Cafe as replacement of my D-Llinks which was corrupted after 6-months. D-Links was secured with the password so that those neighborhood with WiFI...
To manually configure the wireless security on your router, follow the following steps :
  1. Access the web-based utility of your router. To do so, type http://192.168.1.1 in your browser
  2. By default, the username is blank and the password is admin. Unless you have changed those information while setting up the router using the setup software.
  3. Set the Configuration View to Manual
  4. Go to Wireless -> Basic Wireless Settings
  5. Set the Network mode to "Mixed"
  6. You can change the SSID to one of your choice. By default, it is like "Ciscoxxxxx"
  7. Put Channel Width to "Auto"
  8. Click Save Settings to apply the changes.
  9. Next, go to Wireless -> Security
  10. I suggest you choose WPA Personal or WPA2 Personal
  11. Enter a passphrase between 8 and 63 characters and save your settings.
Hope theses instructions help !
May 13, 2011 | Computers & Internet
I forgot my password and cant get on the internet how do i fix
If you can remember your password,reset the linksys router.
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings.
To reset the router using the reset button, use these steps:
1.Look for the red reset button at the back of the router.
2.Press and hold the reset button for approximately 5 seconds.
To acces the router configuration panel -open your browser(Internet Explore,Firefox..)
Type http://192.168.1.1 to acces your pages. Enter user name and password,leave user name blank and enter admin as the password.
Good Luck!
Jan 21, 2011 | Linksys WRT160N Wireless Router
How to enable WPA-PSK on my wireless network? When I open "view wireless networks", I notice that the available networks in my neighborhood are security-enabled except mine. I want my wireless network...
go to an internet browser on a pc connected to router
type in address url
http://192.168.0.1
type admin for the user name
leave password box empty
click ok
don't use wizard
click on wireless button on screen
select enable for wep
select asci
then
type in a password key for the wep that you will remember
click on apply bottom of screen
page 12 - 14
https://fccid.io/KA2DI774VB1/Users-Manual/Users-Manual-1-357565.pdf
Mar 07, 2018 | D-Link Air Xpert DI-774 Wireless Router
I have a Cannon MX860 printer that is set up for wireless. My linksys wrt54g router is also configured for wireless - I can access the internet wirelessly from my mac but the router will not acknowledge...
You need to scan and view available wireless network in printer select your home network (linksys).
Once the printer is ready to go, plug it in and power it on. There should be an interactive set up screen on the printer that you can use to indicate the appropriate wireless settings. You'll want to use the same security settings on the printer that you have set on your wireless router. I recommend using the WEP settings so you are not broadcasting any of your documents or online activity the neighborhood.
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G lost its security setting and also its network name
Log on to Rtr Setup using Default Gateway.
You will find security centre , where you can set up security for the existing network name .
May 31, 2010 | Linksys Wireless-G WRT54G Router
Wireless connection problem
That is the correct access IP address to acces the router properties.
If its a forgotten password you will need to "reset" the router to default by straightening out a paper clip and insert it into the rear of the router till it reboots.
BEWARE this will wipe username and password for the internet and security key. If you dont know your U/N and P/W then call the ISP to reset it.
To enable the above access the router by using the above IP address and re-insert U/N and P/W.
Access security options in the router menu and follow instructions to recreate security password.
Apr 27, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I have bought an Apple Mac notebook but am having problems accessing the internet. I think I have inadvertently changed the password to the wireless router as I have succesfully conected my main computer...
This is a confusing report. If you are successfully connecting two other computers to the router using the original router password, why can't you connect your MacBook Pro to the router using the same password? Or is it that the other two computers "know" the original password but you don't?
If one of the other two computers is a Mac, use the Keychain Access utility to look up the stored password for the router.
If not, use one of the other two computers to access the router's configuration screens directly and obtain the password that way.
Nov 15, 2009 | Apple MacBook Pro Laptop Computer with...
How do I set up a password or protect my wireless from letting everyone in the neighborhood use it. I got the router sometime ago but never found out how to protect my connection. Now I am worried about...
Your default Ip should be
192.168.1.254
Open internet explorer and type that into the search bar..
it should ask for a user name and password, if you never set it for your router before, leave both blank.
that should open up your routers configuration page.. now click on wireless security and turn on either wpa or wep encryption and choose a password.. once you do so you will have to reconnect to your router and then enter the password you just created..
Now you network is protected and only people with your password will be able to connect wirelessly..
Nov 02, 2009 | Blitzz Technology (BWA611) Router
My wireless router was working then the wireless and security light are now off. Wireless internet is not working
Someone in your neighborhood got into your router and turn it off, so they can get and use your internet connection. I would reset the router by the reset button, and right away put a password on it, and then use mac address filtering on the router. This will only allow your computer access to the internet.
Aug 09, 2009 | Belkin N1 Vision Wireless Router
Linksys Wireless-G WRT54G Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
