Question about Home Maid CD250UT Dryer
Kenmore electric dryer - plug too big for outlet
We purchased a used Model #11060612100 and the plug is extremely large 4 prong...we have 120 V small outlet. Is there a way to change the cord on dryer for our use - or do we need to change the outlet? We are renting and can not afford to spend big bucks (hence why we bought used).
Any help would be appreciated. Thank you!
  • 179 Answers
You need a 240 outlet box installed the only dryers that run on 120 are gas dryers you purchased an electric dryer and it needs 240 volts. you need to talk to your landlord and ask him or her to have a 240 outlet installed for you
Posted on Dec 29, 2008
How do you know if it is a gas or an electric dryer
A gas dryer has a small, round, gas inlet port located in the lower rear of the machine, adjacent to the exhaust port. Most electric dryers have a large, 3 prong, 240 volt, electric plug, as the source
of power, although some lower scale units use 120 volts to dry and have no gas inlet port located
in the rear of the dryer..
I hope I was able to answer your question satisfactorially if so, please provide some feedback.
Have a Nice Day!!
Jan 24, 2011 | Kenmore Dryers
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Jul 06, 2010 | Kenmore Dryers
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
I was given a used kenmore series 80 electric dryer, unfortunately the plug doesnt fit into our 3 prong receptacle. What style no.# receptacle would I need. the last one purchased look correct but the...
usually 30 amp and there are several different configuations, they are available at hardware stores, and very east to switch over at the back of dryer. draw up what it looks like and take to hardware store and they should be able to set you up
Oct 17, 2009 | Kenmore 62602 Electric Dryer
I am not sure of the model dryer exactly, but I dont think it matters in this case. The dryer is from a second hand shop, but does not look that old. It is electric, requires a 4 prong 220V outlet. The...
Also on a wing here, but there is a reason for the 4 prong. 2 prongs do control and other 2 supply power to elements. Have seen a simila situation before. Had to use 2 back to back transformers to get drier to function.
Sep 15, 2009 | Kenmore 62602 Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
I am trying tochange my
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Feb 29, 2008 | Dryers
Dryers Logo
410 people viewed this question
Top Home Maid Dryers Experts
Are you a Home Maid Dryer Expert? Answer questions, earn points and help others
