Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door only opens with wall unit
My garage door only opens with the wall unit inside the garage. Both remotes will not work. The wall unit has a continuous flashing green light. Both sensors have green lights. When I press the remotes, the green light flashes on the door opener unit. Confused!!
  • y_porter Dec 29, 2008
    Do you recommend I but a new wall unit, since it's failing.
  • 905 Answers
A component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
  • jason Dec 29, 2008
    yes , it would most likely be cheaper to get a new one rather than having that one repaired , as it may be a chip inside that is not available and the whole board would have to be replaced to fix it plus labor cost
    have you tried disconecting the power to it for a while?(half hour)
    sometimes they can get locked up by a holding charge , and disconnecting the power for a while can reset the components but in time will fail again( temporary fix , if it even helps)
  • 504 Answers
SOUNDS LIKE SOMEONE PRESSED THE LOCK BUTTON. THAT WILL CAUSE THE LED IN THE WALL CONTROL TO FLASH - LETTING YOU KNOW IT IS LOCKED - NO REMOTES OR KEYPADS WILL WORK - ALSO USED AS A VACATION SWITCH.
PRESS THE LOCK BUTTON . THE LIGHT SHOULD STOP FLASHING AND REMOTES SHOULD WORK.
IF THEY DON'T - REPROGRAM THEM.
HOPE THIS HELPS
STEVE
Posted on Oct 16, 2014
Craftsman Garage Door remotes do not work. 139.663953
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Hold the button down on your remote and press and immediately release the smart/learn button. Do this with all your remotes.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,095 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
