Question about Sylvania 6626LCT 26 in. LCD Television
Distorted Picture Our 26inch Sylvania LCD has developed a very distorted picture. Almost animated in nature. The colors are against a white background and very bright pinks, whites, yellows, greens & blues. Manually adjusting the color does not help. Sometimes it will clear up after 10 minutes or so. We have also changed the cable to it and that appears to help some. The first cable had a very thin center wire. Should we be using a specific type of cable? We have only had it 1 year and 10 months.
    Problem Solver:
  • 17 Answers
I don't think that the cable is your problem. Set may have a defective tuner or small signal board. (Tuner is soldered onto the small signal board).
Most likely fix is to find and replace the small signal board with tuner. Should be able to find one for less than $200.
Another thing to try is your video inputs. Use external devices such as a DVD play hooked you using proper video lines and check you inputs. Are they doing the same thing as your cable? If not, then it maybe just a tuner. Some makes and models won't allow you to solder in a new tuner without a full board replacement, but this however may allow you to hookup a VCR with a tuner built in and from VCR to your TV using video input jacks and then programming the VCR tuner to all your cable channels may get your set watchable again without having to tare it apart and replacing a board. However if your input jacks are distorting like the cable channels are, then a small signal board replacement is a must for your set.
Jason
Posted on Jan 18, 2009
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Picture is distorted and jumbled
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 20, 2010 | Hitachi 57F500 57" Rear Projection...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Picture color on screen is all screwed up
The LCD might be the problem ....... I will have to have a look at the pictures for commenting further .....
Oct 26, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Sylvania 6626LCT 26 in. LCD Television Logo
196 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
