Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes don't turn
My steam vac works well except the burshes don't turn. Have checked all filters and they are clean.
I Had the same problem, The brushes are operated by water pressure. Under the machine were the brushes are is a white peice of plastic pull this out and try cleaning the screen. I found this when I removed the cover and lubricated the gears at the brushes, If that does nto work you will have to remove the turbines and lubricate.
Posted on Dec 30, 2008
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not working
brushes not turning are usually caused by the turbine bearings have seized. The turbine cost is about $35 average. on the bottom you can check a pull out filter to clean. there are also 2 screws that are recessd check by hand for tightness that hold the turbine. checkthe brushes for cleaning and free of debris. check the square shaft on the brushes as well. take it to a trusted vac shop who works on hoovers if you are not mechanically inclined for this type of repair.
Jan 15, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7458900 steam vac brushes won't turn
No, there is a turbine that turns the brushes. You can take the top cover off to get to it, open it up and clean it out and then try it again. If that doesn't work, then replace it, or just replace it to begin with.
Jun 08, 2008 | Vacuums
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
103 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
