Question about HP LaserJet M1005 Printer
Scanner Problem HP 1005
I have Printer Model No HP Lasejet M1005 MFP
Scanner Device not move display error report
scanner error no 6
how to slove it?
  • 4 more comments
  • Anonymous Dec 31, 2008
    scan error 12
  • Abhinandan  Patil
    Abhinandan Patil May 11, 2010
    make your problem clear
  • Anonymous Mar 13, 2014
    hp 1005 scanner error 12
    scaner error2 turn off then on. scaner not move what is the problem
  • Anonymous Mar 20, 2014
    HP M1105
  • Anonymous Mar 25, 2014
    how to slove it door open for hp laserjet m1005 mfp door open problem
    Problem Solver:
  • 3 Answers
For resolve this error you should only change the flatbed scanner wiht a new one. this error is hardwere issue.
by.
M.R.Atyabi
Posted on Jan 26, 2009
  • mrezaatyabi Jan 30, 2009
    for resolve the error No.6 or 12 on hp lj m1005 mfp , we should only chenge the scanner system , on this mfp, evry parts on this printer has a part No. please open the 4 screw on the top of flatbed ,then write the part No. and chenge it by a new one.
    by.
    M.R.atyabi
How to solution scanner error 17 in hp m1005
HP LaserJet M1005 Mfp driver pls check the scaner lamp is moving or not i f not pls replace the scanner cable
Jan 09, 2017 | HP LaserJet M1005 Printer
Scanner error 12 shows
HP LaserJet M1005 MFP - Scanner Errors 6 and 12 Solution ISSUE: The scan head may not be in the correct starting position.
Updated firmware is available to resolve the issue.
SOLUTION: Upgrade to newer firmware (version20120831 or newer) available on hp.com Support & Drivers.
Select Drivers & Software, enter the product name/number, select operating system and locate the firmware download.
Nov 01, 2014 | Office Equipment & Supplies
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
Salve ho un problema con la stampante :HP laser jet 1005 MFP la quale mi da errore scanner 12. Come posso risolvere.
clean the scanner (the lamp and the glass) if not working it is a problem and the scanner must be replaced with another one
Feb 24, 2011 | HP LaserJet M1005 All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
HP LaserJet M1005 Printer Logo
1,577 people viewed this question
Seeker5211
Seeker5211
