Cutting the power for 5 minutes, usually releases the lock.
Your electricity voltage is too low.
Frigidaire Dishwasher Error Code = PF
Check / Repair / Solution = A power failure has occurred. More than 10% of power has dropped to the unit. Check house wiring.Feb. 18, 2016
Step 1. Check the other appliances in your kitchen for power interruptions, as an indicator of what might have caused the "PF" error for the Frigidaire dishwasher.
May 22, 2013 - I'm getting the "PF" error code at the same spot... ... Brand: Frigidaire ... verified the heating element has excellent continuity and ... What fixed it for me: I replaced the circuit breaker of the dishwasher on the outside power panel. ... When the door is closed, it gives a PF error and flashes a few times. If I open ...
Feb. 10, 2020 - This is a guide on what Frigidaire Dishwasher error codes are and what ... To fix this error code try opening and closing the dishwasher door to reset the cycle. ... When the i30 error pops up it is saying that the bottom pan has a leak to it. ... that you will run into will be power failure, this is under the PF code.
I had the LC code flashing on my Samsung dishwasher and my mom also had the same problem with her Kenmore dishwasher! We tried everything everyone has posted and nothing worked!! Turns out it was an easy fix! Just add jet dry to the jet dry compartment on the inside panel of the door to the dishwasher and it worked!! No more LC code and the dishwasher now works fine!! I thought adding jet dry was an option?? Apparently it is a requirement with these new dishwashers!!
You have a component down to earth. The problem isn't the start button. Most likely to be the element, but ciuld be wash or drain pump. Check the element with a resistance meter first, when you find the componant at fault, replace it
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
check the outlet where you plug this dishwasher into make sure you have power to it you may have a popped breaker. reply back if this is not the cause.
Exactly what I needed!!
