Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
SATA HDD lost contact
I Have MCP6P-M2 Mobo with AMDX2 3600+ Maxtor 80GB HDD, sometimes HDD lost contact, HDD led ON, and system hang. when restart, hdd can't detect but when take-off the sata cables and put them back again windows boots-up again normally. Any suggestions?
  • 2 more comments
  • juan_carloz Jan 12, 2009
    Have you had a solution about this issue?
    I have the same problem, I have tried with a new HD and it didnt work!!
  • Anonymous May 09, 2009
    ****...same problem. Running Vista Business edition. The computer freaks out/freezes/takes forever to shut down. When it comes back up registry errors are reported, or the hdd just won't boot. Went through two SATA drives with the same effect. The HDDs work fine on other computers.
  • wightlight May 09, 2009
    I have the same problem with this board. Seemingly at random, Windows Vista will freeze, freak out, or take forever to shut down. Upon restart the HDD won't boot or Vista reports registry errors. Restart enough times and everything works fine again...for a while. Went through two SATA HDDs(One Maxtor, One Samsung) thinking they were actually bad - but they work fine in other computers. The first time it was XP - same problem.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    You're effectively, rebooting, your hard drive when you disconnect the cables and reset. I don't think its a hardware problem because it boots up when reset the cables. Before you spend any money on the controller or new cables, just try Disk Cleanup and Defrag. Too many files and gaps on your HDD could cause hangs...not a solution just a suggestion. If that doesn't help any then you may need to buy new SATA cables and see if that works.
  • 49 Answers
The Biostar MCP6P-M2 Motherboard has been reported to be delivered with defective SATA cables. Multiple cases of hard disk drive boot and read/write problems have been reported as solved by replacement of the included SATA drive cables with almost any other manufacturers' cables.
Posted on Jul 10, 2009
  • adriandesdeu May 26, 2011
    Anyone solved this issue by changing sata cables? I did install a new HDD with a brand new SATA cable, and nothing.... the BIOS finds the HDD; but I cannot access it at all in Windows XP Professional. I did boot, and reboot, and changed drivers, uninstall, and reinstall, etc etc. Still no result.
Wtf? I think it may just be the **** Biostar SATA cable. Try replacing with another cable. Never would have crossed my mind. How the hell do you screw up a ******* cable, Biostar?
Posted on May 09, 2009
  • 905 Answers
Get all your info that you need off the hdd before it completely quits, as it is starting to fail and eventually will completely quit
Posted on Dec 29, 2008
what problem, it is not shinny any more? LOL?
do say. please.
I am clueless, so far due to?
what system? PC, MAC,DVR,ext, TV, moon rocket.(LOL)
what OS?
using it as an internal drive, 2nd drive, or external.?
boot drive?
Seagate bought out MAXTOR.
that number must be a bar code, its not the product number
so tell me what it is.
as time passes, maxtor, fades to dark at SeaGate.
but this deep search nets, this, (hidden well)
ive been using MAXTOR since day 1.
decodes for Maxtor :
xa = drive family
- 6Y = DiamondMax(DM) Plus 9
- 6B = DM10
- 6L = DM10 RoHS compliant version
- 6H = DM11
- 7B = MaxLine(ML)III
- 7L = MLIII RoHS compliant
- 7H = ML Pro
- 4R = DM16
- 2F = Fireball 3
- 6E = DM Plus 8
- 5A = ML II
- 7Y = ML Plus II
y = the capacity of the disk, in gigabytes. Drives less than 100GB will have a leading zero (80GB is denoted as 080, etc)
b = buffer size and interface
- J = 2MB PATA with ball-bearing motor
- L = 2MB PATA with fluid dynamic bearing (FDB) motor
- P = 8MB PATA
- R = 16MB PATA
- M = 8MB SATA
- S = 16MB SATA
- F = 16MB SATA 3gbps
All Maxtor SKUs have a zero at the end. It may have a value, but I'm not aware of one.
Example: A Maxtor drive with a model number of 6Y200P0 is a 200GB 7200RPM PATA drive with an 8MB buffer from the DiamondMax Plus 9 family.
now my generic answer: for all HDD. A+ training....(instructor)
1: i make sure it has +5v and 12vdc power, if not all is hopeless.
2: IF PATA/SATA , i listen to the drive case with my ear.
whirrrrrrrrrrrrrr, no whirrrrrrr ,? its DOA.
if it spins its good. if not its 100% DEAD, (RIP)
3: do the gyro test, (if it fights you, as you change it's direction, then it is spinning) Drive in HAND. (whole deal)
4: does BIOS see it? (MOBO BIOS) hot key hit. RTM on MOBO.
yes, good.
no , DEAD. try another power cord to drive or data cable.
try different data ports. on MOBO.
5: try it on 1 PC, with step 4 and 5
6: if BIOS sees it ,so should WINDOWS. (may)
in the device manager.
and in disk manager. (off computer management CPL)
both. set the drive latter in the latter or it will be hidden.
keep in mind BIOS never tests a drive. it only asks it for
its NAME (PNP) PNP just identiifes the maker and type drive. and its spec. and 1 more tests. it shows the drive is NOT BUSY.
these facts ,help all techs, make good trouble shooting.
Sep 24, 2013 | Maxtor Hard Drive
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
MCP6P-M2 v6 not working?
u should change the ram and try again.
Jan 16, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
ATA HDD on IDE connector with a SATA drive on a SATA connector?
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Dec 31, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Problem with my external hard drive.
The HDD is corrupt.Try to re-format if you get your PC to open.
All data will be lost.
To be honest with you,I would not now trust the HDD for any critical or confidential data.
Feb 04, 2008 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
352 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
