Question about BenQ MP611C DLP Projector
Reset the benq mp611 lamp
I can´t reset the benq mp611 lamp after replacement
2 Suggested Answers
SOURCE: cannot reset lamp counter on
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
Posted on Sep 08, 2011
c1apton15
  • 3400 Answers
SOURCE: wHY IS THE PROJECTION FROM
one of your input cables us either bad or not seated properly. Remove cable from projector & re-install tightly.
Posted on Mar 25, 2011
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
May 26, 2011 | BenQ MP620p DLP Projector
WHY IS THE PROJECTION FROM MY BENQ MP611 DLP IS COLORED VIOLET?
Mar 25, 2011 | BenQ MP611C DLP Projector
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
Benq mp610
I replaced my lamp on my Projector MP510 after the projector shut down. I followed the instructions in the book to reset the projector but the projector shuts down all the time. Please can you help me HARRY
Sep 14, 2008 | BenQ MP610 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
REPLACING MY LAMP
Hi Big Dogg
Replace the lamp and reset the lamp timer.
Lamp timer can be reset by holding down the up arrow key and then following the easy on-screen instructions.
Sep 14, 2007 | BenQ MP610 Multimedia Projector
BenQ MP611C DLP Projector Logo
1,379 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
