Question about HP LaserJet 1200 Printer
HP LaserJet wont pick up paper
I had a paper jam and cleared it, not when I try to print the tray pushed the paper up, I can see the wheel moving but the paper wont pickup. I cant figure it out, everything looks like its working but it just wont grab the paper. Any ideas??
  • 628 Answers
Try cleaning the feed roller. It may have debris on it, making it slip. Use alcohol on a lint free cloth. Often you'll see on the paper where the roller slipped on the paper. There may be a dark smudge where the roller slipped. Check it out.
Posted on Feb 07, 2009
Paper jam in tray 2 but there is nothing jammed.
Paper not being picked up, does it have a 3rd tray, take all paper out of tray 2 and see if you can get paper to feed from 3. Also make sure the lever on the cassette tray is in the normal position and check the menu in the settings. Some times the front registration area above the cassettes goes bad, not very common but does happen...place som toner on the wheels in tray two and try to print, see if the toner rubs onto the paper, if it does means wheels are turning, if not wheels are not turning....
Sep 30, 2013 | HP LaserJet 4350 Printer
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Paper Jam at 2
Its probably not picking up paper from that tray, thus the jam error. For me that is typically because the tray isn?t pushing the paper up high enough to be caught by the pickup roller or the pickup rubber band is worn.
Feb 02, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 1200 Printer Logo
281 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
