Question about Crosley CW6000 Front Load Washer
My machine won't spin, they say try the belt but Where's the belt?
My machine sounds like its pumping water out on the spin cycle but the tub won't spin. Everything else is fine... agitator washing ... etc. Someone told me it could be the belt or a thrush bearing. I have removed the panels and tried to locate the bearing but then I found this site and it says something about a belt could be loose or broke. I have looked everywhere as the directions say about removing the access panel and checking the belt. I do not see a belt or the remains of where one once was. I see the transmission housing and all but where is this "belt". And if that's not the case where is the thrush bearing? Please help!
  • mooke Nov 04, 2007
    my macine will not spin at all. I got a new belt and it still will not spin.can u please help me with my problem.
  • bighow Nov 26, 2007
    everything works but it dosenot spin n it sounds like it pumping water
I have a front loader washing machine and it says Lr and won't spin and some times water wont drain
Posted on Aug 10, 2008
I have the same problem with my washer my problem is not the switch because if I put a screwdriver in the switch while the door is open it still makes the sound like it is draining it just won't spin and other solutions I could try?
Posted on Jun 19, 2008
    Novelist:
  • 114 Answers
THERE IS NO BELT ... IT IS USUALLY THE LOADING DOOR SAFETY SWITCH THAT SHUTS OFF WASHER WHEN DOOR IS OPENED DURING SPIN CYCLE. THAT SWITCH CAN GO BAD. THIS IS NOT AN EXPENSIVE REPAIR ...
Posted on Apr 28, 2007
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
No spin cycle
Sounds like a pump problem. If the tub is full of water, it likely won't spin...it's just too much for the motor. The pump is supposed to do it's job first by pumping out all of the water so the motor can spin the tub. I bet the noise you hear is the belt trying to run in a seized v-belt pulley.
Change the pump...bet that does the trick.
Jan 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Crosley CW6000 Front Load Washer Logo
503 people viewed this question
Top Crosley Washing Machines Experts
Steve Allison
Steve Allison
Evan Benson
Evan Benson
tom wright
tom wright
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
