Question about Samsung SyncMaster 910MP 19" LCD Monitor
Samsung mp910 lcd monitor/tv
Screwed up the antenna port to recieve the tv cable line, can the other video/audio inputs work to access the internal tv tuner?. Or should I just use a cable box etc?
4 Suggested Answers
  • 1684 Answers
SOURCE: Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Corporate Compuer
over 21 years repairing PCs and printers
Posted on Jun 17, 2009
  • 233 Answers
SOURCE: want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Posted on Feb 10, 2010
  • 1719 Answers
SOURCE: my lcd tv samsung sycnmaster
Audio comes directly to multimedia LCDs and has nothing to do with display.
Usually, the capacitors are the casue of such blackouts. So, it is recommended that you check the capacitors/ other components such as invertor board and CCFL (lamp), which may be failing or heating up.
Hope it helps! Good Luck!
Posted on Apr 09, 2011
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
May 26, 2015 - Uploaded by
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Jul 03, 2011 | Audio Players & Recorders
Got a 19" LG LCD
To convert a LCD Monitor into a TV
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
How to connect tv tuner
there is a simple way to connect the tv tuner just socket is given on the panel and connect in inlet it .
please give your ratings.....Thanks to giving me chance to help
Mar 30, 2011 | Televison & Video
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See for antenna types and direction or for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
Samsung SyncMaster 910MP 19" LCD Monitor Logo
127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
