Question about Lexmark P315 InkJet Photo Printer
Changed printer cartridge - now won't print red
Changed printer cartridge for first time. resulting photos appeared a bit green (compared to photos printed with cartridge provided with printer). Removed cartridge - no red ink coming out. thought faulty cartridge- so tried another - same problem. Now printer won't print any red, which does produse great Andy Wahol style prints but no good to show the family! :-) Think this is a printer problem as won't clear with a new cartridge, but a bit confused as it happened straight after a cartridge change. Read some other faults on forum - they seem to suggest faults after changing cartridges so wondered if anyone has a fix. As this is a stand alone printer (ie don't need a pc) I'm abit lost as can't reload a driver, etc, etc. So I'm thinking perhaps time to get the screwdriver out and try to reset factory settings??? Help anyone!!!?????
    Sergeant:
  • 390 Answers
You have blocked printhead. You need to remove all cartridges, and thoroughly clean printheads, with solution and cotton buds (q tips) until no residue left. Do printers cleaning systems too, print a test page. Never open the unit unless it is absolute last resort. Try the cleaning. Try completely unplugging unit all cords and cables after switching off and replugging. Try printing now.
Posted on Aug 12, 2007
Why are my prints only printing the reds and blues in photos?
Please next time put the question in the correct category. I still will try to help you.
If your printer does not tell you any cartridge is empty, and it still does not use that colour it could be the nozzles of one cartridge are blocked. Check this by printing a test page, as told in the user manual. Sometimes called an alignment print.
Then check if all colours appear correct. Looks like yellow is not working correct.
May 08, 2014 | HP Photosmart 7520
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hi I am not getting any Red from my printer
It's possible magenta ink to be finished, or the print head is dirty and it has dry ink on it. You must clean it with hot water. You must use the printer from time to time to avoid to dry the ink cartridge or print head.
Mar 08, 2011 | Canon i455 InkJet Photo Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
Excessive Yellow ink use
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Changed ink cartridge, now printing with green hue
check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Sep 24, 2007 | Canon I960 InkJet Photo Printer
Lexmark P315 InkJet Photo Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
