Question about KitchenAid KERS807SSS Electric Kitchen Range
KithchenAid Range KERS807SSS000 Problem--just like the Nov 30th one.
The oven control panel is dead. The cooktop works. It's about 15 months old. I wasn't running a self-clean before it failed. Is there a way to confirm it's the thermal fuse (rather than the control panel itself) before replacing? Can you give any guidance on how to get to the fuse? Thanks a ton for your help--my wife is desperate for a quick repair before New Years!
    President:
  • KitchenAid Master
  • 2,651 Answers
Welll although oyour not running self clean, its possible you have a bad fuse. youll need to pull unit out and get behind to check the fuse for continutity, its a small (quarter sized thermostat) wioth 2 wired leading in and out of it, should have asticker with blue& white stripes on it.heres the part number if needed 9759242
Posted on Dec 30, 2008
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Stopped during self clean--already replaced thermal fuse---it appears cooling fan was never connected, and it does not work once connected. All other functions appear to work, except power to the fan
Is the control panel completely dead?? If the cooling fan under the cooktop was not working, in most cases the main control board or control transformer if it is separate will get heat damaged and need replaced. That cooling fan is there to keep everything from over heating mainly during clean but should come on during normal baking if it gets too hot under the cooktop.
Apr 30, 2015 | KitchenAid KESS908SPS Electric Kitchen...
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
KitchenAid KERS807SSS Electric Kitchen Range Logo
468 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
