Question about M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
Clicking in the headphones while connected to m-audio interface
I hear clicking from time to time during playback of any audio on my computer.. From myspace music to the audio files on my pc, even while recording audio the interface generates clicking causing me to hear it through my headphones and speakers.. Can anyone help me eliminate the clicking??
4 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Recording Device
Pcs needs drivers, and vista is far from being completely stable..
Disconnect the mobile pre...and go here:
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=6&PID=8eb1a9920df341303f81bca7ff458be3&OS=45
then restart and connect.
Rock those beats, and keep me posted.
Posted on Dec 16, 2007
SOURCE: Recognizes the midi interface but not the keyboard
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
Posted on Dec 24, 2008
  • 84 Answers
SOURCE: i can hear the myself
Make sure you've adjusted the Mix knob correctly. The Mix knob is above the Output knob. Turning it counter-clockwise allows you to hear more of your input and turning it clockwise lets you hear more of your playback. Try adjusting the knob clockwise to get more of your playback feed.
Posted on Mar 25, 2011
No sound on computer
hi nina.this could be a lot of reasons why you have no sound.
Update the audio driver using Device Manager as follows:
  1. Connect to the Internet.
  2. Click Start , and type device manager into the Start Search field. ...
  3. Double-click Sound, video and game controllers. ...
  4. Right-click the name of the audio device listed under Sound, video and game controllers.
  5. Select Update Driver Software...
  6. If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones. ... Under Hardware and Sound, click Troubleshoot audio playback.
  7. If you hear sound through the headphones, the sound hardware on the computer is working, and the issue is probably related to the speakers or speaker cables. Disconnect the headphones and reconnect the speakers. When done, test again forsound using the same steps as above with the volume control slider.
  8. If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button..
  9. or go to this link if you need mote help.
No sound on computer Google Search
Nov 05, 2017 | Computers & Internet
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Cannot get audio playback through headphones. Playback is fine when listening through computer speakers, but not through 2i2.
What type of laptop is this, Windows or MAC? If Windows, go to Control Panel/Device Manager and make sure that your USB 2i2 interface is being detected as an external sound card. Then check the Sound Manager in Control Panel to make sure that the external sound card is selected as the playback device. Go back through the setup portion of the users manual. Windows does not necessarily 'remember' settings for devices when they are unplugged and then plugged back in again.
Apr 03, 2015 | Focusrite Scarlett 2i2 USB 2.0 Audio...
No playback through my headphones
Hi, You will need to follow a process of elimination, that way you can isolate problem. first thing you should do is turn every thing off and on. Hopefully windows sorts it all out for you.
If that don't work, plug headphones into a different Jack/usb port.
If that works, it means that you can now isolate problem to your sound card. Next step I would take is make sure sound card is seated in pci slot correctly. Nice and tight. Make sure you have used screw, this will ensure you have good Ground. If you still have no luck. Go to device manager, look for your card. If your card shows up in device manager, click on it to open up different drivers for it. By Right clicking on your card you can have the option to delete / Uninstall driver. Uninstall all the drivers for your card and restart computer. Windows will think It's new hardware and will reinstall drivers. I reckon this will work. The only other thing I can think of is to bring up playback devices on your system tray and make sure that it is actually set to playback on the device of your choice.
That should give you something to do for a while. Good luck.
Oct 24, 2017 | Tascam US-122 USB Audio/MIDI Interface...
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Yamaha GO46 firewire audio interface
Hi. It might be a bit late, but the solution to your problem is the fact that the phones level is dependent on output 3-4. If you turn 3-4 all the way up you should be able to hear something. You might want to route all the outputs to the digital mixer.
Aug 23, 2008 | Yamaha GO46 Sound Card
Headphone jack
when the sound device is installed it should give you sound effect manager or sound device,to access this go to START then CONTROL PANEL then SOUND SPEECH AND AUDIO DEVICE,open Sound Effect Manager,then Sound Effect,select Headphones from the Enviroment Dropdown and click ok.test this output now.
If this doesn't resolve the problem ,
reinstall device again.
Jul 09, 2008 | Acer Aspire 3680 Laptop
Lambda doesn't record, though it seems ready to go
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Jan 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Open Questions:
See all M-Audio Mobilepre USB Bus-Powered Preamp and Audio Questions
M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card Logo
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
