Question about Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea Monitor Troubleshooting CT1700
Hi maybe you could help me... I have a problem with my LCD Cornea CT1700... When I light it on the monitor will go off after 10, 15, 30,60 or more minutes? I have 3 monitors with around the same problem... I have to disconnect the monitor for 5 to 10 minutes and I can use it again for a while... What could be the problem? They were brand new and they had already this problem... Also the problem will occur immediately if I change the resolution of my screen... Any part I could change to correct the problem?
  • 2,961 Answers
Duplicate posting see below for solution
Posted on Apr 28, 2007
When I turn on my Cornea MP503 monitor on it has a message in a blue box saying Power Saving Mode and then goes blank and light flashes orange-green over and over.
Check the VGA/ DVI cable connection from your Monitor to PC, this also could be caused by VGA card on you PC that doesn't work properly, unfirmed connected to its slot etc, check also for unfirmed connected memory card/ RAM.
Dec 13, 2010 | Cornea MP 503 15 in. Flat Panel LCD...
Where can i find a power cord for a Cornea CT1700? I live in Greensboro, North Carolina
josdcabr, do you need only the cord or the "black-brick" switch-mode-power-supply" 12vdc @ 3.5 amps rating. You might try unitedsale. com in Valley Stream N. Y. 12fixlouie
Aug 10, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Need driver for Cornea MP704
I have the same monitor on one of my test benches. For a long time I tried to find drivers for this because I thought it would make a difference. Finally a year or so ago I found a drivers company which said they had it. For $20 I could download it and many others. I did so and didn't really see much improvement when I installed it. I finally got to thinking that maybe I should look closer at this code I purchased. Well as I suspected this code was actually the Microsoft generic LCD monitor code which had been relabeled. I turned it over to Microsoft. But to answer your question I have never found drivers that are specific for any Cornea monitor. Sorry
Mar 24, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Polarity for power supply for cornea mp 704 lcd monitor
There may be a virtually invisible polarity symbol on the case next to the connector.
Apr 20, 2017 | Cornea MP 704 17" Flat Panel LCD Monitor
Monitor Driver
you can download the driver for your CT1700, from this URL:
be happy always
Jul 17, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
it could be something as simple as your power settings in control panel> power options, then the first window called power schemes pops up and all monitor, harddisk and system standby should be set at never. Also check on you monitor menu for any power saving options and turn them off. If the monitors still turn off then there has to be a deeper fault with the monitors and not with the power options.
Apr 28, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
Cornea CT 1700 17" Flat Panel LCD Monitor Logo
217 people viewed this question
Top Cornea Computers & Internet Experts
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
