Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door only opens with wall unitq
My garage door will only open when I hit the wall unit inside the garage.
The remotes will not work at all. When I hit the remotes, the green light flashes on the garage door unit. The door sensors are both green, but the wall unit has a continuous flashing green light.
  • rbayless59 Dec 31, 2008
    Does this solution work when the inside button has but a single button and is not a three-button unit with a dedicated "lock" button?  How do you unlock the sytem using a single-button switch?  How did I manage to lock it?  I've lived in this house for 13 years.
    The light on my single-button wall switch is blinking and neither of my remotes is working.  The door still operates from the wall switch.
  • jamie2tammi Apr 09, 2009
    I have a single button wall switch and my remote is only one switch. The wall button will operate the door but not the remote. I can see the l.e.d. light blink when I push the remote but nothing happens.
  • 37 Answers
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Posted on Dec 30, 2008
The remote opener in my far works, but the garage door opened on the wall of my garage will not open the door. What is wrong?
Perhaps the wall opener control needs to be accepted by the opener, press the button on the opener head unit and then press the wall switch. Consider new batteries before you do so.
Mar 04, 2011 | liftmaster Garage Door 1/2 Hp
Have to hold down keypad on wall to get door to
You may have a relay faulty or the wiring is connected wrong.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door remotes do not work. 139.663953
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Hold the button down on your remote and press and immediately release the smart/learn button. Do this with all your remotes.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,062 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
