Both air bags on rear will not air up. They went down at the same time. The compressor runs and bags do not come up. Any suggestions, I do not want tp buy more parts than neccessary. J. Humphrey
If the compressor is working and actually pumping out air, might need to check your lines dont have a leak by disconnecting them from the bags. If pressured air is making it to the end of the line, then bags may need to be inspected and one or both replaced. However it is more likely that the lines are leaking or the compressor pump needs a service. Just a new set of rings in the unit. Good luck, hope it helps.
1999 ford expedition my airbag compressor comes on every couple minutes my right back side is low and don't know where to start troubleshooting
both airbags wont air up and compersor keeps running every couple of minutes
