Question about IBM ThinkPad 600E 2645 Notebook
Will not load windows I get an error message stating unmountable boot volume
  • aaron01141 Jan 17, 2009
    I have IBM 600E laptop and won't load windows. All I see is the size of the RAM blinking on the screen.
    Novelist:
  • 151 Answers
I) i think you hard disk or hard drive(of your laptop or desktop) is malfunction or not working properly.....
   or it has gone bad, i think you have to send it for repair or replacement;
   error messge: unmountable boot volume is specifically for harddisk malfunction and requires repairing or replacement(strictly)
Thanking you
M. Sridhar
Posted on Dec 29, 2008
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Dell dimension e310 desktop error message unmountable boot volu me
> unmountable
The disk-drive cannot be "mounted", i.e., the motherboard cannot access it
> boot volume
To "boot" a computer is to load a small "loader" program from the disk-drive;
that program "pulls-up-by-the-boot-straps", to read the rest of Windows from the disk-drive.
If the disk-drive has "failed", then you'll get messages like the one that you reported.
Replace the disk-drive.
Jun 12, 2011 | Dell Dimension E310 PC Desktop
No complete starting
Unmountable boot volume means your harddrive has gone out.You will have to get a new one and load your os again.Sorry:-(
Apr 08, 2010 | HP Compaq Presario C502US Notebook
The unmountable boot volume message is on
perform 32 bit diags on hdd using drivers disc, if no error, boot your comp using windows disc and perform recovery console, perform chkdsk /p
Feb 23, 2010 | Dell Inspiron 1545 Notebook
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have the same issue and my aspire is idle for last 4 years...
Jan 12, 2009 | HP Compaq nx7010 Notebook
Umountable boot volume
power down the pc unplug it and when it restart up go to F2 and see if you booting in c or in your cd rum try this
Dec 20, 2008 | Dell Dimension 4300S (Refurbished)...
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
303 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
