Question about Frigidaire ATF6000ES Front Load Washer
Door will not lock error code 36 displayed alternating with dr code
  • 3 Answers
Code 36 is - Control board problem = Replace control board.
Posted on Dec 30, 2008
Dr is displayed and will clear. oven or cooktop notworking
Error code DR can refer to a door lock malfunction. Try resetting by turning off the power to the oven for at least 5 minutes. Power back up, if the error code continues you may have a faulty door latch, or light switch, or in worst case Electronic control unit.
Dec 05, 2014 | Kitchen Ranges
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Range elec #fef352awf oven will not work digidal code comes up Dr?
Hello Mike, an error code DR commonly refers to a door lock malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit on. Typically, this will clear most false error codes. If the error code continues to display, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements. I hope this information proves to be helpful.
Aug 03, 2013 | Frigidaire Ovens
Dr error code
Good Morning Herb Reinhart - An error code DR commonly refers to a door lock malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear most false error codes. If the error code continues to display, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
Apr 09, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
Dr error code
“do” or “dr” - door problem. The door is not locking, the control is not able to confirm the door is locked. Might just be corrosion on the door lock connection. Or a bad door lock OR an item in the door keeping the door from locking. Manual and more here
Aug 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load stackable gets a code dr. model#fwtbb30ds0
Hi.
Error DR is door latch error.
Check the door lock, and ensure that it it closing and opening properly.
Disconnect power cord or trip circuit breaker for one minute to reset the error code.
If the error code comes back, then the door lock may be faulty.
The door lock may be tested removing it from the washer and reading Ohms on the terminals to ensure that it is opening and closing the circuit. An alternative way to test the lock is by jumping it, if error comes back with door latch jumped, then fault is on wiring or controller board.
Here all parts and diagrams for this appliance.
Regards.
Ginko.
May 19, 2010 | Washing Machines
Won't start and the display alternates between dl and f
Hi. This is a Door lock mechanism failure code.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit. Make sue it is mounted correctly, and not loose.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
If the door lock unit is mounted correctly, and the wires that link the device to the main control module, and connected well, this will lead to a failed lock mechanism. replace the door lock mechanism, in this case.
Nov 18, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code DR
dr is a door error your door is not closing or your door lock is faulty
hope it helps
Aug 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
