Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Fluxuating Sound The sound fluxuates while watching anything. It gets really quite, so I turn the sound up then suddenly it increases to what I assume is the correct volume. I have quite a bit of experience sodering cards and connections. Could this be the problem? Thanks for the help. -Caleb
  • 68 Answers
Just resoldering at volume board , try to just hit the tv at aside if the sound alters then re solder regards please don't forget to rate thx
Posted on May 04, 2007
My gadges on my 2000 chevy malibu keep going off and on. the car keeps moving but the gadges drop. why is this.
Hi, I had the same problem. For my malibu (2000) it was a faulty ignition switch. I replaced it and the instrument panel works fine.
Feb 19, 2013 | 2000 Chevrolet Malibu
Does it really work to clean my IAC or do i need a new one
They are expensive, costing anything up to $150, so I'd try cleaning it first. There is a good chance that will be enough.
Jan 22, 2013 | 1990 Toyota Camry
No heat and engine temp gauge is too high
no heat engine running hot sound like faulty thermostat which is sticking closed.if thermostat stuck closed no coolant can circulate through the engine block and radiator causing no heat condition and engine overheating.replace thermostat and radiator pressure or surge tank over jug cap see what happens.
Dec 09, 2011 | 2003 Kia Sedona
2007 Chevy Silverado oil pressure gauge fluxuating, setting off computer on dash reading "engine oil low" also warning bell sounds. Thanks!
If you are lucky , replacing the oil pressure sender unit will solve the problem. Your truck might have perfectly good oil pressure , but a bad sensor. OR you might actually have low oil pressure , which is not good , and will be expensive to fix. Good luck.
Dec 15, 2010 | 2007 Chevrolet Silverado 1500 2WD
2006 suburban oil pressure gauge fluxuating
Most likely it's the oil sending sensor, located beside the oil filter. You can change it, just be sure to have old newspaper or rags laying around the area where you will work, because a little oil will be lost. The part isn't expensive, for mine on a Ford Expedition was around $35 and took 5 minutes to change. Just un-plug the connector going to the sensor, and a larger wrench will be needed, large (7/8, 15/16) somewhere in that range of size.
Jan 06, 2010 | 2003 Chevrolet Suburban 1500
Oil leak in my 92 jeep cherokee
The most likely place for an engine to start leaking oil (when it's coming from the top and not the bottom) is around the valve covers -- the gasket goes bad. Next most likely is camshaft seals.
Sometimes just tightening the valve cover botls will stop it or at least reduce it.
Apr 29, 2009 | Jeep Cherokee Cars & Trucks
Idle s 2300rpm when cold, then revs between 1500-2000, while..
maybe vacuum leak or intake manifold leak. sounds like components are doing there job adjusting to air intake, matching the amount of air brought in with the amount of fuel that it would demand to produce correct emmission quality. check this out. you can use carb cleaner to spray around your throttlebody and intake manifold and if the engine idle fluxuates you have a leak.
Apr 15, 2009 | 1991 Mazda 626
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
