Question about Nintendo Wii Console
Remote When I move the controller it is moving the oppisite direction on screen(e.g. i move left-it moves right) has anyone got a solution?
  • Anonymous Apr 07, 2009
    when im playing with the wii zapper the pointer in the game moves to the opposite way it also happens in the lobby and evey game
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...........................
Posted on Apr 07, 2009
Google screen only (all other screens are correctly positioned) has moved right, can't access right side of screen. can't adjust
Press the windows key on your keyboard, and while holding it down, press the the left arrow key. that will move it to the left.
Dec 05, 2014 | Google Chrome
Need to know how to put tv code in a direct tv remote
on your directv remote move the switch on the top to right until on tv. then hold select and mute on remote until it flashes twice. then enter 981. that will clear any memory on remote. then hold select and mute again until it flashes twice. enter 9911and use the channel/page up button and press it up once at a time until tv shuts off. after tv shuts off press select. then hold select and mute again until flashes and enter 960 and that will let it control inputs. then move switch back to left on directv logo and enjoy.
Mar 25, 2012 | RCA DIRECTV Satellite Remote Control
How do you reverse the fan to move the oppisite direction for summer. Our fan is controlled by a remote.
My parents had a cassablanca fan that utilized a three button remote and if I am not mistaken to reverse the direction you held down two of the buttons at the same time for approx 3 seconds and the fan would make a different beeping sound than it does normally when changing fan speeds and bingo it changes direction. It should work, all fans work basically the same . Good Luck
Jun 27, 2010 | Hampton Bay 23509 Fulton Ceiling Fan
Right analog on ps3 gets stuck on top left direction
the circular thing that lets it move freely probably cracked, making it harder to move. i had to buy a new controller because of this reason.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Red lines all over the screen
this set(AV56wp74) was first made in 2003----if you use the remote for the set and go into the customer menu---select convergence----once there see if the red and blue will move left/right and up/down----if either color will not move in any one of these directions----you have a bad convergence IC--this set uses 2 of the STK-392-110 output ic chips---both need to be replaced and the set adjusted with the original JVC remote control. I hope this has been helpful.
Aug 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Mtd mower will not move forward or backward.rear wheels won't move. When I lift mower up,rear wheels move opposite directions...
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
May 01, 2009 | Garden
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
Controller moving in the oppisite direction
You're holding the controller with the black part facing toward your TV, right?
Also make sure there are strong light sources in the same direction as your TV. This can sometimes confuse the Wii remote.
Apr 02, 2008 | Nintendo Wii Console
Wii Remote Problem
oh no!! i suggest that have to reformat your console. Maybe, some of its drivers tend to malfunction..
Feb 05, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
76 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
