Question about HP 530 Notebook PC
Installation failure- HDD not detected
I have an existing installation of Winxp on my HP530, when i try a fresh installation by booting from the CD at the Windows setup screen I get two options -
1) Fresh installation press enter to continue
2) For recovery options press R.
When either of options are selected it doesnt detect the HDD. The existing installation works fine though. Please help
Thanks in advance
Murli
  • murlinambiar Dec 29, 2008
    Thanks, it worked. Amazed at the speed & accuracy of the response
  • killerbunny Feb 19, 2009
    I have an existing installation of \Vista on my HP530, when i try a fresh installation of winxp by booting from the CD at the Windows setup screen I get two options -
    Genius:
  • 1,913 Answers
May be your harddisk is not detected.
check in bios settings.
and disable sata otion .then try.
Posted on Dec 29, 2008
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
I cannot get windows to load..goes to an error screen which asks me to choose repair(recommended) or start window normally...then repeats
Run diagnostics on the system (Hold Fn Key and press Power) and see if the HDD fails diags. If it does, then replace the HDD.
If the DIags PASS
Boot to your windows XP CD, press R at the 1st prompt to enter recovery console, the run the command CHKDSK /R then see if the system will boot normally.
If no go, then reboot to the WIndows CD and continue the install and try a repair install of WIndows. If that fails, then try a clean install of Windows (Delete the existing NTFS partition and create a new one)
If all those fail, replace the HDD (Passing DIAGS does not ensure the HDD is good, just the diags didn't detect the failure)
Nov 03, 2009 | Dell Inspiron 1545 Notebook
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
My a300 canot get to the advanced boot screen pressing f8, it just asks for a bootable disk. after the toshiba screen it says that there is no bootable device. i want to just reset my computer to the...
Your OS is not booting. There may be few reasons.
1) Your hard disk is damaged and your BIOS does not recognise your HDD. Goto BIOS setup and see whether your HDD is shown. If it does not appear there, you may have to replace the Hard Disk.
2) Your HDD is recognised by the BIOS but Master Boot Record (MBR) is missing or damaged. Try booting from an XP CD. See whether Windows Setup detects your HDD. If the setup says there is an existing installation, try repairing it. After repairing, reboot and see whether you can use the computer. Otherwise make a new installation.
Aug 12, 2009 | Toshiba Satellite A300-0CF035 Notebook
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
HP 530 Notebook PC Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
