Question about Fantom Drives 120 GB Hard Drive
Problem with my PC recognizing my external hard drive
I have owned my fantom drive for about 1 yr. Recently, when I turn on my fantom drive, my PC did not recoginze the drive anymore. When I click on properties, it does show on the description that I have data stored in the drive, but when I click on the drive, it only shows a blank page. I called the fantom drive company and a tech support staff told me to buy software so I purchased a "recover lost data" software (40 bucks down the drain). When I tried the software, it did not solve the problem since I never deleted the information, my PC decided one day not to allow me to see my data anymore. I have also used the disk defragment and the check for errors programs on my PC with no luck in sight. I have windows XP on my PC. The fantom drive appears to work fine since the LED light turns on. Can anyone shed some light on this matter, I don't want to take it into a shop since I'll only get charged an arm and a leg and can't afford it, Thanks.
  • ricks19 Dec 06, 2007
    Similar problem with Fantom Titanium 500 GB drive. Does not show up as a drive on computer any longer. But if I look at Disk Drives in Device Manager, it does seem to be listed there. But when I look at the Volumes tab and ask it to populate, it can't read any data. We get same problem with drive attached to two different computers. Seems like the drive can't read the stored data any longer. Still under warranty so we can send it back, but would like to try to retrieve the data. Any suggestions?
    President:
  • 2,961 Answers
If you know the files are there and the drive cannot be read then there must be a read error, the only other thing to try is a different usb or firewire port as the port itself may not be reading the drive. Try it first by putting in a different port while the pc is on then plugging in and then restarting if the device is not recognised. You may also try the drive in a friends pc to see if it is port trouble and not the drive
Posted on Apr 28, 2007
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Sep 30, 2010 | Fantom Drives 120 GB Hard Drive
Two yr old fantom titanium 80g. not being recognized by computer. not even firing up. running windows xp OS.
Fisrst replace PSU test all leads that attach to your hard drive including the ones from your motherboard and eltrical+elec extensions make sure they have a secure connection or just replace them with new leads
Aug 20, 2010 | Fantom Computers & Internet
I have a Fantom 500 GB external hard drive approximately 2.5 yrs old. Recently it has had difficulty starting up in which I hear a soft "click" but the drive does not come on. Help.
your drive needs to be looked at, sounds like it is severly broken, it may be unrepairable. but they may be able to get info off it..good luck
Feb 28, 2010 | Fantom Drives 120 GB Hard Drive
Unrecognized FANTOM HDD volume
have you try it with another system? if no try it and if it continues then try scanning it with antivirus program installed in your system. if all this no success then get and another okay.
Nov 11, 2009 | Fantom Titanium Hard Drive
My PC doesn't recognize the external drive. I think PNP is working properly because other devices are immediately recognized.
you need to go to delet all the drivers that you have by going to control panel, system, device maanger and delet the drivers reboot and the system will start reading asll your drivers again and it should work..
Nov 07, 2009 | Fantom Titanium Hard Drive
Fantom external drive 1T runs but not recognized
are u using the usb cable for connecting the drive? use usb ver2.0.
May 17, 2009 | Computers & Internet
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Drives 120 GB Hard Drive Logo
179 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Jim Goldsmith
Jim Goldsmith
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
