Question about Mitsubishi WS-65869 65" Rear Projection Television
My picture is starting to look green.
When I turn on my TV the background is green. When the picture is showing it still looks green. I can see the colors but it has a green tent over the picture.
5 Suggested Answers
  • 18 Answers
SOURCE: Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Posted on Dec 27, 2007
  • 6 Answers
SOURCE: Red and Green
check video IC or tv convergence sometimes yoke
Posted on Aug 18, 2008
directcurent
  • 59 Answers
SOURCE: New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Posted on Jan 23, 2009
  • 185 Answers
SOURCE: When I first turn on the TV everything is clear
convergence section starting to break down will need attention
Posted on Jun 22, 2010
c1apton15
  • 3400 Answers
SOURCE: After power went out and came back on the TV
With your remote you should have menu that lists changing tint, aspect etc... the power surge sent it back to factory default.
Posted on Jan 03, 2011
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
My tv looks weird red and green. The people are bright red/orangish and backgrounds are green. The picture is perfect. I already reset. I believe the colors are out. I want to change myself. Can you help.
If the convergence appear to be correct, the next step is replace the fluid in one of the projection TV tubes. You will have to very carefully remove the screen and see into the mirror which picture tube is not clear. All the instructions will be found to fix this, by searching the this website....TvRepairKits.com. Have your TV model number and chassis number near by. Thanks for asking and show a few hands of support.
Jan 16, 2011 | Philips 60PP9202 60" Rear Projection...
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problem with rca hd52w58 52" tv
This can be a green crt or green driver pcb problem. You can try and unplug the tv for 30 min. and plug it back in and turn it on, but the problem will most likly still be there. A repair shop will need to fix it from there.
Oct 22, 2008 | RCA HD52W58 52" TV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Green is not being displayed on my TV
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Sep 08, 2006 | Toshiba 32AF41 32" TV
Mitsubishi WS-65869 65" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
