Question about HP Pavilion dv9060us Notebook
Distorted DVD Palyback
HP dv9060 DVD playback was choppy, hissted and distorted. Thanks jaranya8...your the "Top Dog" in my book! My problem existed since October...thought I needed a new HD DVD Drive, but after downloading the XP_Codecs that you suggested and reinstalling my Conexant High Definition Audio Driver, it's like having a new PC.
Thanks,
r2000ace Miami
Sorry for the new post, new to "FixYa" and did not know how to reply to your fix.
  • r2000ace Dec 29, 2008
    You can disregard this request. you solved my problem audio playback problem on 12-28-2008.
    Thanks
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Hi, thanks a lot for the vote. If you have problems, just drop me a comment. I am here to assist you.
Head alignment
Tracking controls for VHS should have no effect on the DVD player. If a pre-recorded DVD is distorting the picture, along with the VHS, then there's either something wrong with the TV it's played on, or the connection, between the two. Or there is a fault in the electronics of the VHS/DVD combi that deals with the picture.
Dec 29, 2013 | Zenith Televison & Video
Audio from cd playback distorted all other audio perfect
what program are you using, and are they traditional cd's or burnt?
Jul 22, 2012 | HP Presario Cq56-115Dx 2.3GAmd Notebook Pc
HD DVD Audio playback is distorted after microsoft
try uninstalling the audio drivers completely, restart and re-install them
Mar 11, 2010 | HP Pavilion dv9000z Notebook
I have a dell dimension 3000 desktop and the sound from the cd/dvd rom drive is distorted or choppy when i play a dvd rom or a cd
hi go to start, settings, control panel, click on sound and audio devices. on the volume tab locate properties and click on it. now another box will appear look for cd volume and adujst it whist playing a cd until the sound is less distorted. please rate me if this solves you problem.
Feb 23, 2010 | Dell Dimension 3000 PC Desktop
E-System laptop with slow dvd playback
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
Hope this helps.
Mar 09, 2009 | Computers & Internet
DVD Playback is choppy & distorted.
Use compressed air to clean DVD driver.
Clean virgin DVD surfaces.
Use commercial grade cleaner for DVD drive.
Dec 28, 2008 | HP Pavilion dv9000z Notebook
Audio and DVD playback problems
Hi, sorry for the difficulty in using the system. I will advise you reload the operating system again. Make sure it's from the real manufacturer, I mean don't go for pirated. If it doesn't work, then back up your files and folders and format the system. I wish you the best.
Dec 18, 2008 | Dell Inspiron B130 Notebook
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Playback of a cd or dvd
not really..
is this a new problem or an old one?
Oct 25, 2007 | Computers & Internet
Dvd playback
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Oct 07, 2007 | Bose 3·2·1 Entertainment System...
HP Pavilion dv9060us Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
