Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher & paykel trips the electric sockets
My 2 year old fisher & paykel which has needed repairing 3 times, had a problem draining the top drawer, we ran a few cycles with it empty hoping to empty it, but now if we turn it on at the socket it trips out and all the othere electric sockets in the kitchen, this happened on christmas eve, and I cant get anyone out to it until the 8th Jan. Has anyone any idea's
  • sharonasplin Jan 02, 2009
    Thanks, I took drawer out and dried the bottom with towel, and the power board with hair dryer. It is now working like a dream. Thanks very much.
  • 232 Answers
Does it trip power as soon as its plugged in.drain hose may have gotten kinked behind drawer and broke leaking on to power board behind lower drawer. THE POWER to this thing must be removed before taking anything apart on these dishwashers. IT IS RECCOMENDED TO HAVE A TRAINED TECH WORK ON THIS they are delicate good luck!
Posted on Jan 01, 2009
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Jan 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I am having problems with the bottom drawer not draining in my Fisher Paykel dishwasher. How do I drain the water? the last time a repair man came for this same problem, he was able to punch the keys in a...
You can do 2 things: If this problem persists it means that the "flap" that prevents the water from draining into the drawer needs to be replaced, unfortunately this is a common problem with this model if you are a frequent user. In the meantime what the tech does to empty the drawer is to run the shortest cycle which will empty drawer but you know if you need the "flap" to be replaced if the problem persists.
Nov 24, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Top drawer is draining into bottom drawer and bottom drawer is draining into top drawer
Hi, Make sure that the drain hoses are looped at least as high as the top washing part. With no loop the water is free to pump from one drawer to the other. I simply tied the hoses up under the sink with twist ties. That was over 2 years ago and haven't had the problem since. Good luck!
Jul 14, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
306 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
