Question about OKI Pacemark 3410 Matrix Printer
I have an Okidata Pacemark 3410 and the alarm light is blinking and will not print. i turn on and off and the alarm light just comes back on.
  • Anthony Lam May 11, 2010
    what other lights are on? Blinking alarm = hardware fault need the other lights to pinpoint what is causing the fault.
    President:
  • 8,637 Answers
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Paper jams, upper feed roller does not turns.
Either a paper jam is keeping the roller from turning, or there is a problem with a belt or gear drive assembly. The unit will have to be inspected carefully, but if no jams are spotted, it will have to be disassembled to assess the problem. You can take it into a local computer repair shop, or contact OKI for support:
http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet
Good luck, and hope this helps.
Mar 01, 2011 | OKI Pacemark 3410 Matrix Printer
Print settings and network
is that printing compressed only if u use foxpro?
Feb 08, 2008 | OKI Pacemark 3410 Matrix Printer
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
Apr 16, 2010 | OKI Pacemark 3410 Matrix Printer
Pacemark 3410 - printer shuts off after 30 seconds
Good chance the power supply is burned out. Located in the rear bottom of unit. You must remove the whole machine from case to get to it. Costs about $200.00 at any shop.
Aug 04, 2009 | OKI Pacemark 3410 Matrix Printer
Theres power but no lights coming on
I think your power supply fan is faulty ?
Hope this helps.
Dezzi
May 27, 2008 | OKI Pacemark 3410 Matrix Printer
OkiData Pacemark 3410
Resolution:
Using HP JetAdmin.
Select Device then Modify
Next until arriving at the Options screen.
Here is where we make the necessary changes to the parallel mode and handshaking
Click on the pull down arrow and change the parallel mode to Centronics and make sure handshaking is set to nACK and Busy then click Finish. Reboot the JetDirect box and cycle the power on the printer.
Feb 11, 2008 | OKI Pacemark 3410 Matrix Printer
Printer Alarm Light
Your carriage motor could be the problem.
Dezzi
Nov 20, 2007 | OKI Pacemark 3410 Matrix Printer
Oki pacemark 3410
Is the operating system Unix?
Oct 31, 2007 | OKI Pacemark 3410 Matrix Printer
Okidata 3410 pacemark not printing correctly
Well, I had that problem once. What I did was that I used the printers cleaning tools. You can acces them by entering Printers in the ControlPanel. Then right click on your printer and select Settings. Look through there. Worked for me.
Apr 06, 2007 | OKI Pacemark 3410 Matrix Printer
OKI Pacemark 3410 Matrix Printer Logo
567 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
