Question about Rockford Fosgate Power 1500.1BD Car Audio Amplifier
Need help My amp worked when put away. Then a year later when I tryed to hook it back up and it makes a high pitch noise and the protection light comes on. If I push down on the bottom of the amp it quiets down.
    Genius:
  • 1,139 Answers
Hello koty,
That sounds like you may have a problem with a bad solder joint on one of your switching transformer connections. If you have a soldering iron and some solder, you should resolder the transformer connections. Also check the whole board for bad solder joints. If this does not work there might be a chance that one of your capacitors has gone bad due to aging. You will need an oscilloscope and a schematic to measure the voltages on the capacitors to make sure that they are within the recommended ripple voltage range (open capacitors loose their ability to filter so the ripple voltage increases and this causes instability in the DC voltage level). However the fact that when you apply mechanical pressure the problem abates, this is pointing towards a bad solder connection.
I hope this helps,
Thank You,
Shuttle83
Posted on Oct 18, 2007
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
High pitch whirring noise on starting car
contact the mechanic who did the job and have him arrange for the vehicle to be transported back to his shop for repair . He will be responsible for any work and parts that he used and for the recovery of the vehicle . If there is a problem then seek legal advice to recover all costs from him if he will not honour his work.
Apr 18, 2014 | Cars & Trucks
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Makes high pitch whistle
Do you have the brakes taken apart once a year,
on all your vehicles, for rust removal,inspection,
needed work & lubing,that is required
Have to flush brake fluid every 2 years, if you
don't want moisture in the system ruining it
Don't know what the noise is,work on the
brakes & then get back to the noise, if it's
still there
Jul 24, 2013 | 2010 Mercury Milan
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
1991 Ford 350 truck, in dash cassette player high pitch noise
Hi rayc
sounds like the motor that pulls the tape mechanism is probably about to give problems and is getting electronically noisy. The cb may need to hooked up some where else to power so you get away from dirty power as well as maybe move the cb farther away from the tape player. hope this helps.
Ray
Aug 31, 2009 | Maxon MCB-40 40-Channels Handheld CB Radio
Wont turn on and high pitch noise
Looks like the printers internal electrical components have gone. if there is a tranformer in your printer then that is making that noise. or else even the motors might also be gone.
my strong suggestion take it to any authorized service personnel
Apr 20, 2009 | Computers & Internet
Wont stay on
try a new battery
Feb 15, 2008 | Nintendo DS Lite Console
Samsung slimfit television 30"
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Aug 11, 2007 | Samsung TXM3096WHF 30" TV
Rockford Fosgate Power 1500.1BD Car Audio Amplifier Logo
103 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
