Question about Belkin (F5D7230-4) Router (587009)
Router won't lock
We have tried a number of times to lock out router (wireless connection) and when we press & hold it in for 3 seconds as instructed, the light does not come on signifying that it is locked & it will not lock
  • ccnewell Dec 29, 2008
    Thank you, I will try that as soon as I get the chance :)
  • 1,913 Answers
U have to reset your router check in back side of router 1 reset button press it for 5 second then it restert and reset.
Posted on Dec 29, 2008
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->>
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
My wireless N router is not recognized at my pc . the setup page doesnt work, the wireless light is off basically nothing is working.
You can try the following steps..
1) At the back/base of the router there will be a small hole/button as and hold it using a tooth pick or paper clip and hold it for 10 seconds..disconnect the power from the router and connect it back after 10 seconds and check whether the setup page works. 2) If the above step doesn't work press and hold the reset button for 40 seconds..after 40 seconds while still holding the reset..disconnect the power cable(keep holdin the reset) and connect the power back after 40 seconds(While still holdin the reset) and then let go of the reset button disconnect the power for 10 seconds and connect it back and check if the router setup works.
The wireless light will be lit only after a computer is connected to your wireless network. If the above two steps didnt work it looks like the router may be fried. You can get it replaced from Belkin as they have lifetime warranty on this product. The number is 1800-223-5546.
Hope this helped.
Feb 17, 2011 | Belkin F5D9231-4 Router
Router connects to the internet using cat 5 cable but not wirelessly today. Worked fine yesterday. Icon in system tray has my home network connected, but, it says "no internet"
try pinhole resetting the router. Hold it down for 30 seconds, then pull the power, then press and hold it for 30 more seconds, then plug the power back in.. then press and hold it for another 30 seconds and let go.
Try connecting wireless again, if this doesnt work the router is broken. Get a new one.
Feb 05, 2011 | Linksys Wireless-G WRT54G Router
Cannot connect to wireless Linksys WRT300N router. Power off/on, but only the internet indicator ON, wireless indicator OFF... Router is diagnosed as hardware failure, just want to see if there is...
Hi Friend,
You need to try hard reset of your router. Please follow the steps:
1. Power on the router.
2. Push and hold the reset button for 10 seconds (watch whether the power light blinks or not)
3. Turn off the router for 10 seconds and switch it on.
4.Once the power light is steady then perform the steps 1-3 for 2 more times.
5.If the wireless light still shows off, then kindly get in touch with the Linksys technical support centre.
If the wireless light turns to be good and steady then follow the steps to configure the wireless settings:
* Type in the address bar of the web browser and hit enter.
* Type admin as password and leave the username blank
* Click Wireless and fill the sections as mntioned:
Network Mode: Mixed
Netwrok name: As per your choice
Radio Band: Wide-40mhz
Wide Channel- 6
Standard Channel:1-2.412GHZ
SSID Broadcast: Enabled and click save settings.
* Click Wireless Security and fill the sections as mentioned:
Security Mode: WPA Personal
Encryption: TKIP
Pre-shared key: Any ten digit number and click save settings.
turn the router off for 30 seconds and swithc it on. use the pre-shared key to connect your wireless devices.
I hope this will resolve the issue.
Dec 08, 2010 | Linksys WRT300N Wireless Router
I have a second hand linksys router, but dont have the software or CD to install it, how do perform the connection to my PC? thank so much for kind help
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Connect the wire (which is coming out from the modem) to the WAN/Internet port of the router.
2.Connect the computer to either of the four LAN ports of the router.
3.Turn on the router and press and hold the RESET button for 30 seconds. Turn off the router and turn it on after waiting for 30 seconds.
4.Type in the address bar of Internet Explorer and hit enter.
5.Leave the username blank and type admin in password.
6.In the setup page make sure Internet Connection type is set to"Automatic Configuration"
7.Click MAC address clone and select Enable and then click the tab CLONE. After that click Save Settings.
8.Now click Wireless(to configure wireless) and fill the sections as mentioned
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
9.Click Wireless Security and fill the sections as mentoned
Security Mode-WEP
Default Key-1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
10.Since it is a second hand router, I would suggest you to please upgrade the firmware
Please follow the link:
Enter the model number and click the Download tab. Then enter the version number(which you will get once u turn upside down the router) and download the firmware and save it on desktop.
11.On the router setup page click Administration and then click Upgrade Firmware.
From here upgrade firmare and turn off the router for 30 seconds. Turn it on and enjoy.
Jun 13, 2010 | Linksys Wireless-G WRT54G Router
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
My old 2wire 2701hg-b router went bad and I replaced it. I had a netgear wgr614 attached to it for a second network and now i can not get the netgear to attach although all lighs appear okay Showdave
Its just locked up as it can't see your old router, 2 resolutions:
If you have have backed up your config settings for the router or you don't have any set then press and hold the reset button for 30 seconds, now let go and power the router off, now power the router off and back on again>this will reset the router back to factory defaults and you now connect back up to the router but you will have to setup your broadband logon again.
The second option is to connect the router via an ethernet cable and reset the router and it should let you connect wirelessly again.
Sep 09, 2009 | NetGear WGR614 Wireless Router
Need to re-setup my router. the router lost connection a few times. solved by power disconnect. now does not connect at all. type COMPEX NetPassage 27G Wireless-G 54 Mbps Extended Range.
Try to hard reset the router by pressing the reset button at the back of it. Hold it down for 30 seconds then unplug the power for 30 seconds. Reconfigure it
Jun 01, 2009 | Compex NetPassage 27G Wireless Router...
Wireless G Broadband 2.4G Router
Try to reset the router for 20 seconds. There's a reset button at the back of the router. Just press and hold it down for 20 seconds, then unplug the power for 30 seconds, the plug it back in. Now try to reconnect to the Linksys wireless network.
Aug 21, 2008 | Linksys Wireless-G Broadband Router
Belkin (F5D7230-4) Router (587009) Logo
201 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
