Question about E-Machines eMachines Desktop PC
Keyboard does not work
Sometimes when I take my computer out of the hibernatestate, my keyboard does not work. I need to reboot my computer to correct theproblem. The keyboard wire is securely connected to my pc. My computer model is T5216.
    Master:
  • 413 Answers
Need to what? I'm not sure what the rest of the question is but it sounds like you need to keep your computer from going to sleep mode. You can do this by clicking on your start menu then going to control panel then inside power options you can turn sleep mode off. There really is no real reason for a home pc to go into sleep mode.
Posted on Dec 29, 2008
Fujitsu-siemens pi 2530 change keyboard
change keyboard is a function of operacional system:
Step 1: identify the layout> american, universal, european?
Step 2: click on keyboard icon>rigth side on task bar> choose the correct layout and language
Step 3: setup as Default
Step 4: sometimes the reboot is needed.
Jul 16, 2014 | Fujitsu SIEMENS Amilo Pi 2530 Switch Board...
Someone gave this model acs54 need manual to hook it up 4 speakers and power unitAS SEEN ON YOUR WEB SIGHT
You could try to get it at this website:
http://www.alteclansing.com
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 11, 2011 | Altec Lansing ACS 56 Computer Speakers
MY NEW KEYBOARD WILL NOT LIGHT UP
If you plugged your keyboard in while your computer is on sometimes it wont respond. By rebooting your PC it should clear this issue right up for you. If this does not correct your problem, message me and I will be happy to further assist you.
Regards,
Nico
Jul 09, 2011 | Dell Computers & Internet
My keyboard stopped working
What kind of keyboard connector does it have?
If the end of the connector is round with pins (serial connection), just plug the keyboard back in and reboot the computer. With that style of connector, if they get knocked out or come loose while the computer is running, they will not always work again until you reboot.
If the keyboard uses the flat plug (USB) connector, the computer should be able to pick it up again without a reboot when you reconnect it. Also note that if the keyboard is USB and it stops working; if you have any other USB items hooked up as well (IPod, webcam, external drive,etc), check to see if any of those devices are still working either before rebooting your system. Sometimes, another unrelated USB device may crash causing ALL USB devices to fail simultaneously. If this is the case, unplug all USB devices except your keyboard and reboot. If the keyboard works again, reinstall all of your other devices one at a time until you locate the one that crashed all of them (if that was the case).
Hope this helps.
Mar 19, 2010 | Dell Computers & Internet
Sometimes one of my computers *always same one) doesn't recognize the mouse and keyboard.
This is a common problem with KVM switches. To isolate the problem, here's what you need to do:
1. First, connect the keyboard and mouse directly to the problem computer to ensure that the keyboard and mouse works correctly while being directly connected.
2. Swap the connection of two computers. If you're having a problem on the computer that is connected to port 1 of the KVM, connect that computer to port 2 of the switch or just swap the connection. If the problem recur on port 1, then there's a problem with the keyboard and mouse cable on port 1.
3. But if you're not able to duplicate the problem on port 1 or 2, disconnect the KVM switch from the computers, leave it disconnected for 5 minutes.
4. After 5 minutes, reconnect the KVM to the computers and reboot the computers.
5. If same problem occur, then contact the manufacturer of the KVM and have them RMA the device.
Thank you!
Feb 09, 2010 | Edimax EK-PS2C (EKPS2C) 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
F keys don't work on reboot. Work on Power on boot.
Turn your computer off.
Temporarily replace your keyboard/mouse with "generic" units.
Turn your computer on.
Check that the F-keys work.
Restart.
Now, do the F-keys work correctly?
Or, do you still get "keyboard failure"?
Jul 22, 2009 | Computers & Internet
Lenovo 3000 v100 keyboard problem
sound like a connector problem .. see this website for the removal instructions
http://www.lenovoservicetraining.com
Dec 10, 2008 | Lenovo ThinkPad T61 Notebook
Keyboard will not type at all
try a friend keyboard to see if its keyboard or computer if keyboard replace it if computer right click c:\ properties tools error check now fix errors and reboot see if keyboard works sometimes this method fixes system and registry errors hope it works for you
Jul 16, 2008 | Computers & Internet
Keyboard problems when booting up
i can advise you with this.
it may help if you disable the original keyboard, as you may have a device conflict between the 2. you can do this from within windows.
ensure your drivers are correctly installed, for the keyboard, and the motherboard. Go into My Computer/ Control Panel/System/Device Manager And see if you have any yellow exclamation Marks. this will determine that the Device is functioning correctly. And if not you can update the driver or find the conflicting device.
Finally ensure this is the first keyboard that the computer sees, adjustment in the bios configuration.
Mike @ Compurepair.
Mar 08, 2008 | Acer Aspire 3100-1405 Notebook
E-Machines eMachines Desktop PC Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
