Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Cd decks numark no sound
Numark CDMIX3 NO SOUND , the cds are been read in both decks but there is no sound coming out what so ever.
  • Anonymous Mar 28, 2009
    I get no sound from my numark cdmix3, it I'm runnin it to my stereo reciever and get nothing though the cds are playing.
SOURCE: Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Posted on Sep 27, 2008
SOURCE: problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Posted on Feb 15, 2009
SOURCE: numark cd mix 2 is not reading disk on left side
First clean the laser lens
Posted on Jun 24, 2009
  • 17 Answers
SOURCE: Numark icdmix2. Jammed cd's
Power cycle while holding eject button?
This unit should still be covered under warranty. I would contact Numark for an RMA.
Posted on May 06, 2010
Right hand deck makes ticking sound & will not read cd
The laser pickup is shot, the whole assembly will need to be replaced in order to get it up and running properly.
Apr 23, 2012 | Nu Mark Numark Cd-Mix-2 Dual CD...
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
I hve a gemini cd 200 and the left deck stopped reading cd's. when i put in a disk the lcd reads no disk. What cuold be the problem.
Just like with any CD player, the optics have lifetimes. Either the optics are dirty and can not read the disk or they have failed. These units use KSS-213 optics assemblies from Sony, if I remember correctly. These can be purchased for around $25. Any one with audio repair experience should be able to replace them for you.
Dan
Jul 31, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
Numark HDX system needs upgrade: Insert upgrade cd?
You just need to type Numark Hdx in your search engine or on numark's website, and they have the download for the firmware update. Download and burn to disk. Turn on your deck holding the eject button until it ask for you to insert the disk you burned. Go thru the prompts and let it install firmware *NOTE DO NOT TURN OFF DECK* or you will ruin it.
Jun 12, 2009 | Numark HDX Turntable
I have a Numark HDCD1 that Drawer 2 will not read any CD I put in it. The CD plays in Drawer 1 when I put it in there. I also have already replaced the cable from Drawer 1 onto Drawer 2, and it still does...
I may be a little late, but for this problem you might have pirate cds burned off your computer in which the HDCD1 will not be able to read, could be the format.
Dec 15, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
