Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
Just bought new Sharp HDTV and hooked up cable box (output 1) and bought new component cables for Wii to hook up to back of TV (output 2). I cannot get DVD/VCR component to work. Had to hook it up to inputs on side of TV because that was the only place for it and because those colors matched those on back of DVD/VCR recorder. Cable cords are going out to TV from this unit and in from cable box. I get no sound at all and picture only from DVD part. I need both to work. Thanks for any help.
  • Anonymous Mar 26, 2014
    I want to watch/play my DVD player to my TV but could not despite of my proper connection (i think?) of the three collored cable wire
  • 8,596 Answers
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Posted on Dec 31, 2008
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Hooking a dvd and vcr to a cable box and tv
You will have to use an audio/video cable for connecting the player to the tv. This cable consists of three wires, generally a white, a red and yellow. Yellow is for video and the other two are for audio. You will find corresponding colored sockets both behind the tv and the player, find out which is the input at the tv and output at the player. Good luck
Jan 30, 2008 | Sharp 25H-M60 TV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,220 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
