Question about Nintendo Wii Console
WIRELESS CONNECTION! PLEASE HELP
I go through the whole connect process and everything work out fine. I have been on the shopping channel and weather channel and even updated the wii. Obviously I'm connected but when I go to the Wii menu screen there is no box to link systems together so I can play my buddy online. PLEASE HELP!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
I am not absolutely sure but I think you are suppose to add them into your address book on the wii mail near the bottoms og the screen at the wii menu.
Posted on Mar 14, 2009
Hello.... trying to connect to Wii shop channel and i'm getting error code 051030... unable to connect to server... I originally had my server provider hook up everything ... and I was able to access Wii...
If you think it's a connection problem, go check out the Connection Settings in the Wii settings menu. Run a connection test, and make sure your settings are correct. Re-enter your WEP key and such if you're using things like that.
Error Code: 051030
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
* If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
o If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
o If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
* Check for interference that may be preventing a successful connection. Click here for tips.
* Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
* Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
1. Login to your router's settings (click here and select your router, if available, for information).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
* Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
* The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
* Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
* If the problem persists, try our general troubleshooting steps.
Wireless Channel
If there are other wireless devices in the area, they can interfere with the signal so much that the Wii console will not be able to connect to the router. Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1, and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab. =D
Mar 15, 2011 | Computers & Internet
Intermittent internet disconnection, yet internet is fine
Please check the firmware of your router first. in most of the Wireless router the connection dropping issue is due to old firmware, also try chaning the wireless channel to 9 under the 2.4 GHz network to optimise the Wireless connection.
Mar 16, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I just got router and the wii shop channell doesn't work but the weather news channel work?
If your connection isn't very strong you will have issues connecting to the Shop Channel. Verify your connection. The problem also may be a necessary update. Go to your settings and get the latest Wii system update.
Feb 22, 2010 | Nintendo Wii Console
Wireless MADNESS!
Hello M.,
It appears that this is an annoying problem for you. Here is the deal: it is typically cordless phones that mess up the connection. By default, routers are set to a LOWER CHANNEL. Grab the manual and access your router's settings and navigate to the wireless section. Find the channel setting and pick one of the highest one (think like channel 11). and presto,reliable connection...
ALSO, be certain to invoke security on the wireless connection.
Doc
Sep 17, 2009 | Belkin Computers & Internet
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear wg111v2 wireless constantly connects and disconnects
Set the security on the wireless router to WEP and perform the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 09, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Im having problems conecting my nintendo wii to my tiscali siemens gigaset se587,can you help me please as i have tried to link them both together with a wireless conection but i just get an error message?...
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck IAN.
Sep 02, 2008 | Video Game Consoles & Games
Action hbs not getting IP
I have the same problem, were you able to find a fix?
May 15, 2008 | Fortec Star Lifetime ULTRA
Wireless router connected and everything enabled but still says not connected
You said the wireless connection is disable, Did you enable it already by right clicking on it and selecting enable?
May 08, 2008 | D-Link Wireless
Nintendo Wii Console Logo
46 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
