Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Mrs Cleaner flex has pulled out how do I replace Electric supply wire to switch on handle has broken at switch. How do you remove switch to repair? tonysimmons
    Genius:
  • 1,239 Answers
Hi
Mrs Cleaner - dsc04925t.jpg This should go without saying, but the first step is to unplug the machine. Next, open it up and remove the bag. Now you will need to remove the lid. There are white plastic clips on either side that you must carefully disengage by pushing them towards the center of the machine. Click the picture above and you can see that the right side clip has been disengaged. dsc04923t.jpg dsc04919t.jpg Once the clips are disengaged, the lid can be lifted clear of the body. Note the thin black plastic tabs on the lid that insert into slots in the body. Set the lid aside someplace safe where nobody will step on it. As an aside, I have twice replaced the dust channel, the fragile black piece of plastic visible at the top of the lid. Fortunately it is not a terribly expensive part and it is very easy to replace because it is only secured by four screws. Go back to the vacuum cleaner body. The next step is to remove the air filter. It is secured by two fairly obvious screws. These screws also hold down the switch assembly, which we will remove in the next step. But for now, go ahead and remove the screws and lift off the air filter. Put it aside where you won't lose it. dsc04915t.jpg Here you can see that the air filter has been removed and we are ready to remove the switch assembly. At this point the only thing holding the switch assembly to the body is the electrical connector underneath, and a plastic pin or two. Get a good grip on the switch assembly and lift it straight up with a firm but gentle tug. This is the underside of the switch assembly after it has been removed from the body. The white rectangular electrical connector in the center mates to the black rectangular electrical connector in the body, seen on the next picture. Put the switch assembly in a safe place until we reassemble the vacuum cleaner. dsc04910t.jpg Here we see the body with the switch assembly removed. We're almost there. The next step is to remove five screws, one of which at upper left is hidden in a deep recess. Click the picture above to see the location of these screws. The five screws have been removed. Carefully flip the vacuum cleaner over so that the black bottom and the wheels are pointing up. dsc04909t.jpgdsc04906t.jpg Here it is, belly up. Nothing is holding it together at this point, so just lift the entire base (the big black part) off and set it aside. It is not necessary to remove the rubber bumper that goes all the way around the outside of the base. As I learned the hard way, It is difficult to reattach. The inside of the base is likely to be pretty grungy. You could clean it up a bit with a damp cloth (I did), but there are wires in there so I wouldMrs Cleaner - dsc04908t.jpgo wet. Mrs dsc04902t.jpg At last! The Miele's  innards are exposed. The motor is at the bottom of the picture and the cord winder is at the top. Remove one screw securing the cord winder electrical connector and then disconnect the electrical connector. You may now lift out the cord winder and replace it. I was also having an intermittent electrical connection problem which I thought was related to the problematic cord. It turned out to be an unrelated problem with one of the electrical connectors in the center of the machine, pictured above. Part of the plastic clip designed to hold the connectors together was cracked. Unfortunately I did not have a replacement part, so for now I wrapped some electrical tape around the connector to hold it securely together. This seems to have done the job. But the next time something else breaks on this Miele, I will order this part too and replace both at the same time. Follow the instructions in reverse to put your vacuum cleaner back together.I hope you found my little tutorial useful.
Posted on Dec 29, 2008
    Sergeant:
  • 306 Answers
Remove the bucket from the front of the machine and the handle and pipe from the back on the front of the switch housing you will see a screw remove this screw on the back you will find two little catches one on either side push these with a screwdriver then the sides of the switch housing will pop out from the chassis now on the front theres another on the bottom of the housing push this down and pull the housing off from the front when replacing this part be carefull not to trap any wiring
  • 13,433 Answers
Hi
I can't see your vacuum so I'm guessing here, you need to take the handle apart to get to the switch and then replace the switch with another one, and possibly the handle if its broken also, you will need to take note of how the wires are set up right now write it down on paper or somewhere so you know how to wire it up correctly again.
it maybe best if you take the vacuum to someone who has experience in electronics and can fix it for you.
  • Dyson Master
  • 19,396 Answers
Click on the following website to find complete diagram for your hoover:
Dyson DC07 Part Diagrams
  • Ginko
    Ginko Dec 29, 2008
    To replace the switch ryou must emove the bucket first, and also remove handle and pipe at the back side of the switch
    housing, where you find a screw.
    Undo the screw on the back to
    find two little catches. Press them with a
    screwdriver to release the sides of the switch housing.
    On the front side you find another catch, located on the lower side of the housing.
    push it and release the housing.
  • Ginko
    Ginko Dec 29, 2008
I have a sebo automatic X 1.1 which has stopped running....because of the electric through the handle. How can I fix this issue?
could be a loose connection in the handle or a broken wire in the handle
take it in to an appliance repair shop and have it checked out
Jul 13, 2016 | Sebo Vacuums
There is no power. fuse checked. I have stripped down the vacuum cleaner but still does not work
Almost certainly there is a break in the wire inside the flex. This happens most often just where the flex enters the handle (less often where it enters the plug). If you have any means of checking for electrical continuity, with the machine unplugged from the mains remove the handle and check for continuity between the pins of the plug and the sockets at the end of the handle. If you can't do this yourself, you will need professional help.
If there is a fault in the flex close to the handle it is possible to remove the flex from the handle, cut off the damaged bit and re-wire the remainder into the handle. To have a professional do this may well cost more than just fitting a new pre-wired handle.
Good luck! If you need more help, just post a reply here.
Apr 04, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
How do I remove and replace the on-off switch on hoover upright self propelled vac.
Greetings,
This is a relatively easy fix for you. What I've done for you is take pictures of this repair on your type of vacuum to make it as easy as possible. I will explain step by step what you need to do in order to fix the switch on your Hoover.
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Plyers
- Hoover Windtunnel Switch
Step 1. Turn the vacuum cleaner2_bing.gif so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you may remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the bag housing and set the bag door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose plyers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the front side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope that this was helpful in fixing your Hoover Windtunnel switch. If you found this helpful, please be sure to rate the repair as helpful by clicking the Thumbs Up Icon in the top right hand corner of the repair. If you have any questions, or need some help on this repair, please just use the Clarification Request option here on Fixya, and I'll be happy to help you further.
Thanks so much,
Chris J.
GoVacuum
Feb 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
NO POWER
The problem is almost certainly a fatigue break in the flex. These usually happen where the flex enters the handle through the rubber sleeve near the on off switch. You will need to cut about four inches off the wire and reconnect it to the switch. To do this, you need to remove the on/off button as you have suggested. If you press the green button down, you will see a tiny slot at the side of the button on the side nearest the handle of the cleaner. You will need to slip a small screwdriver with a blade about 3-4 inches long down the slot, in order to disengage the little hook at the bottom of the button moulding that clips it into the body of the cleaner. This is a real fiddle and you will probably mark the casing in the attempt. I have done it dozens of times and I still end up shaving off the ridges I have made in the plastic so the button doesn't stick when I reassemble it! Once you have done this, you can draw the buttup upwards and take it out. This will reveal a philips screw holding the switch button in place. Unscrew and remove the switch, then cut and re-make the connections after removing the 4 inches of flex. You will need to replace the spade connectors on the wire, or cut, solder and insulate the re-joined wires before re-assembly. If you are handy with a solder iron or have some small spade connectors to use, go for it, but be sure you are competent to make this repair. Usual rules for dumb people apply her folks. UNPLUG from the mains before you start tinkering around!
Mar 12, 2009 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
295 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
