I have water draining out of the bottom of the freezer, the freezer is working and the ice and food are thawing...help
SOURCE: Ice forms on the floor of the freezer
sounds like a defrost problem there should be a defrost control and some form of a heater onthe inside of your freezer you should call a technician for proper diagnosis on which part you will need
SOURCE: drain keeps freezing
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
SOURCE: water runs out of freezer have cleaned drain and
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
SOURCE: there is water from somewhere in my woods upright
Sounds like air infiltration gasket issue or power outage? proper freezer bags will stop the burning.
